Which is the best routing?
  • Which is the best routing?
    Hey all
    Just need advice. Think i know the answer but want to check.
    I have a speaker in each of my 4 doors. All speaker cables run to the head unit at the front of the car. The head unit will be removed.
    Now, to save me pulling off door cards etc, I am going to run the speaker cable from where the head unit used to be, and route it down 1 side of the car, along with my other cables.
    Which side is best to run the speaker cables? :
    1) With the power cables, remote switch etc (left side of car)
    2) With the vga, composite, usb, camera cables (right side of car)
    I want to eliminate the chance of alternator noise as much as possible.
    I think its best to run it with the vga etc, but i dont want the speaker cable to distort the image on the screen/camera or interfere with the usb stuff.
    Anyone know if i am right?
    Ta
    www.leoncupra.co.uk
    Run them whereever you want. It's highly unlikely to make a difference! You won't get alternator noise on speaker level wires that's only line level. (And never forget that the entire vehicle chassis is a power cable.)
    VGA cable should be shielded so don't worry about that.
      Dude, they are not line level. They are not pre-outs, they are the amplified signal.
      As in the cable that goes directly to the speaker terminals, from the amp.
      www.leoncupra.co.uk
        That would be speaker-level...
        Re-read the reply, man...
        How about the Wiki?
          oh hang on, i gotcha. i thought he said that the cables i was running was line-level..
          oops. sorry. now i understand. Cool
          www.leoncupra.co.uk
            My grammar was a bit confusing.. sorry! ;-)
              not sure I understand how EMF interfernce would be differnt for line- or speaker-level cables, but I think you should run them on the same side as the VGA and USB cables.
              My first carPC!
              MP3/CD player
              Celeron 633MHz - 10GB Seagate - 64MB PC100 - Win XP
              Soon to actually find its way into the car!
                yes, hannibal is right.. just be sure your power cable is far away from your other cables.
                Also be sure your caontact wire (blue) is not parallel with your audio cable...
