Audi Dash kit
  • Audi Dash kit
    Hey fellas. Long time since I've been here, but I've been through a few cars since I had the idea to do the car pc thing. Any how I know have an Audi A6 (2000) and I want to mek this as painless as possible. So my first question, as I'm sure many more will follow is if any of you out there know if a Dash Kit (designed to be used to install either a 1 or 2 din aftermarket HU) can be used for one of the more popular screens sold here. This I think will be mush easier for me, and I could probably even have a car stereo installer do it for me. Any Audi owners out there care to voice in on this be my guest. Then again I'll take anyone's advice. Good lookin out.
    smokeyb
    Yep
    :: DISPLAY
    <> There is an INDASH kit for the xenarc, lilliput, etc.
    :: CPU
    <> CaseTronic makes a case that is 2" by 7(ish) but it's 10" deep.. a limiting factor for some dashes (so check yours).
    The case tronics fit the epia M series motherboards.. which peak at about 1.3ghz and are by some estimations not the most powerful cpu. but your milage may very along w/ your specific needs.
    •Micke
      did a search on what you are recommending
      I came across something that looks like a conversion kit for the lilliput screen, which allows you to put it in a in-dash housing of some sort. That looks cool and all, but not exactly what I'm looking for. What I wanna do is install the screen flat up, basically to give it an almost factory look. I want the screen to use the entire double din opening provided. Any suggestions on how I can find a dash kit to fit around the edges of the screen itself?
        You can do it, it will have to be fabricated one way or another. Good luck.
