Please explain a typical carputer shutdown
  • Please explain a typical carputer shutdown
    Okay, so Opus and the ITPS (depending on which route you take) appear (to me anyway) to shut down the motherboard, but that doesn't really shut down windows, right?
    Can someone please walk me through their shutdown and bootup processes? Are you employing some method of telling windows to shut down? Are you going through the standard shutdown and reboot process every time you start the car (seems like it would take a long time)? Is there software to do this that I simply haven't stumbled across in the hours and hours of searching this topic? Any details would be GREATLY appreciated.
    James
    My first attempt at a carputer.
    PM me if you're interested in a monitor faceplate for your '99-'04 Golf or Jetta. My Vortex ID is NorthAtlR32 - you can IM me there, too. Go here for more information.
    Windows xp has an option when you press the power button it will begin shut down then power off when done.
    I GIVE FREE HUGS!
    Buy Sell or Trade
    If my pm box is full, please feel free to call me any time. 440-328-3382
    Thank you
    Forex
    Rate Mp3car @ FXroot.com
      Thank you... XP is 2000 based, no? Does 2000 also have this feature? And then the bios (?) is changed to start windows on power restore? And finally... doesn't that take a while to boot up?
      And now I can't understand the big deal about the Opus. If your carputer has to completely boot from OFF and turning the key from OFF to START takes microseconds, what's the big deal about not maintaining power to the CPU for those few microseconds? I'm NOT opposed to spending the money! I simply want a more compact package than the 150W Opus housing.
        2000 i dont know i dont run it, im sure it may. Look in power options i think.
        As for the opus its the watts and being able to survive crank. When you start your car your car sucks a lot of juice droping it to like 10volts and then up to 13-14 or something like that then will level out to 12v. The itps waits for it to level out. Then turns your computer on.
        I GIVE FREE HUGS!
        Buy Sell or Trade
        Thank you
        Forex
          Will do! Thanks.
          As for the opus its the watts and being able to survive crank. When you start your car your car sucks a lot of juice droping it to like 10volts and then up to 13-14 or something like that then will level out.
          Now that you mention that, I do recall reading that tidbit earlier today on mini-box's site. So since we are talking about a complete boot up, the Opus saves a few seconds. Whew!!!
          Thanks again! Since I'm not Windows SE certified, is there information stashed somewhere (sticky, FAQ) that provides tips on how to set up windows for the best boot results?
            its around here some where.
            I GIVE FREE HUGS!
            Buy Sell or Trade
            Thank you
            Forex
              read all the posts about problems with ITPS. Unfortunately as is the way in life if you want the best you can't scrimp
                Yeah, but my itps is doing fine right now. no problems so far with that. knock on wood.
                Think of the opus like this. If you were to have the 12v direct from battery to computer with no opus. When you turn the key, your computer thinks its ok to start, then after you try to turn it over the voltage drops, computer go O NO what happend to the power and shuts off then power is restored and comptuer goes ut o i hope it dont do that again lol. Opus says its ok computer I wont do that to ya. Saving computer from headache.
                I GIVE FREE HUGS!
                Buy Sell or Trade
                Thank you
                Forex
