add rs232 port to laptop? help!
  • add rs232 port to laptop? help!
    Hi guys, just started on my car pc with an old laptop and a trident touch screen kit, i found the old laptop was just to slow to run anything so now have a new one (cracked lcd) this new beast has firewire, 3 usb ports, dvd, and modem/network card built in. problem is my touchscreen kit. the tft plugs into the ext vga socket and 12v supply and works fine but the glass touchscreen overlay plugs into a control board which connects to a rs232 port on the pc which i now dont have! any ideas?
    PB 2.0Ghz, 20GB, 512mb, XPpro. 300GB Usb HDD, Griffin pwrmate, m-audio audiophile fw. BU-353 gps. 2x100w sony amps, 1x150w JBL sub amp, MBQuart front components, 6x9 rear, 10" sub. Audiocontrol epcienter, esp2, 3xs. Clifford G5, Finished, fitted, problems
    usb to rs232 adaptor
    or
    a docking station (make sure it has an rs232 port on it though!)
    Fox Mulder
    2004 Toyota MR2
    Modified Intel Xeon E5450 3Ghz Quad Core 2GB RAM 160GB SSD M4ATX Xenarc 700TSV TS Toslink Audio BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
      i have to load software on to the pc for the touchscreen, if i get a usb adaptor will it just function the same? cheers.
        It should, the USB adaptors add a virtual serial port. Unless the software does some low level stuff that interferes with this, it will work.
        StreetDeck.com Developer (I am Chuck)
        Get StreetDeck at http://www.streetdeck.com
        The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
          if you get the usb to rs232, make sure you get a good one that actually created a com port. I bought one from compgeeks for $7 that turns out to only work with palms and scanners, and printers (i think)...I then picked upa belkin that works like a charm.
          (By the way, this was for my obdII)
          mykolJay
          99 Accord coupe
          http://www.geocities.com/accordpc
          My Project Thread on mp3car.com
            forgot to mention, the board for the touchscreen overlay can get its power through the rs232 line. i presume this is 5v. would this still be provided by an usb to 232 adaptor, i put my tester on my old laptop but it did not give out any power on the pins the manual said. can the output of an rs232 port be altered by the software and does anybody know if this will work via a usb thingy? thanks for the help!
