Hibernate file on CF card?
  • Hibernate file on CF card?
    I searched and couldn't find anything on this, but would it be possible and has anyone tried putting the hibernate file on a CF card to speed up hibernate and wake up? I would think if windows can recognize it at startup it would be a ton faster than loading from disk w/ say a 60x CF card.
    umm...hmmm...i remember a thread about this....but i think it talked mostly about have all of the windwos on the card....but just he hibernaton files...hmmmmm
    DICE Los Angeles
      i did the same research. no can do
      Falcon cr53 w/ via epia m10000. Nokia 3650 blutooth phone.
      Better than winamp. Click here for qcd player.
        You can, if you have a CF-IDE adaptor. Then windows (and everything else) will just see it as a HDD. Without special drivers.
        BUT, CF-cards are not necessarily faster (please tell us, if you test it ) AND they only have a limited number of writes before they start slowing down (but as you only will write to it when going to hibernate, that should be ok)...
        The adapters are 20 bucks or something...
        List of front-ends/usefull apps
        XTroniC | XTroniC Direct
          I'm pretty sure that CF cards are much slower than HDs, something like 10,/sec read and 9meg/sec write, its not going to be faster than a hard drive
          PowerVoice v1 | NaviVoice Source
          GammaControl v2.4
          SKINbedder v3
          1995 Lexus SC300
            BUT seek times are nearly 0
            Then again, for reading one big file, that won't do much, lol
              Yep
              GammaControl v2.4
              SKINbedder v3
              1995 Lexus SC300
                what's the read rate on a laptop drive? I know it has a burst of 100mb/s but after the cache, what's the read speed? I know a 100x CF card is 15mb/s continuous.
                  I don't have to search I'm beting its more than the 100x CF card, esp for a 7200rpm drive
                  GammaControl v2.4
                  SKINbedder v3
                  1995 Lexus SC300
                    CF cards are waaay slower, it's closer to a CD-ROM speed than a hard drive speed.
                    肚子笑痛了
                    S60 Install
                      Does anyone have any use, any use at ALL for the CF adapter on an Epia MII ? You can't boot from it, you can't hibernate off of it, whats it good for?
                      http://www.cardomain.com/id/seanklsc
                        Copying filess from my digital camera....
                        Of course I don't have a CF reader with which to accomplish this, so it really doesn't matter...
                        How about the Wiki?
                          I just found a benchmark, the highest I've seen is 36mb/s for a notebook drive. Now if u could create a flash RAID0...now THAT could be interesting. That would require some more hardware though. Guess my hopes are crushed of a quicker boot from hibernate.
                            Random storage/picture copying.
                            GammaControl v2.4
                            SKINbedder v3
                            1995 Lexus SC300
                              TigerDirect has the incredibly fast CF cards, get a one gig, put XPMCE or XPE on there, with enough ram so that the entire OS can be buffered into ram.
                              Quick! To the Popemobile!
