CPU Fan
  • CPU Fan
    I was curious the fan on my m10K is really noisey. Has anyone replaced this and if so what did they use or do you have any more info on this. Thanks
    If it's noisey then maybe something is wrong with the fan itself (that particular one). I replaced mine with a vantec copper heatsink and fak.
    Mine needs to be updated.
      @samc
      Is the copper heatsink a direct replacement for the stock one or did you have to figure out a way to mount it?
      Epia M10000 | Travla C134 | Lilliput 7" | Opus 90w
        The one I got was an upgrade for one of those vga cards. I don't have a pic but it was basically flat with a fan built in. I just had to cut off a fin and what not to make it fit in, dremel stuff. Otherwise it fit in with the stock pins.
