Pentium M Mini-ITX mobo with AGP slot !!!
  • Pentium M Mini-ITX mobo with AGP slot !!!
    http://www.kontron.com/products/pdpr...eySiteRegion=7
    LVDS, LAN, 4x USB and 4x COM, 1x AGP/DVO, 1x PCI
    # Intel® Pentium® M and Intel® Celeron® M Processors
    # Front Side Bus 400 MHz
    # Intel® 855GME + Intel® 6300ESB Embedded Chipset
    # Intel® Extreme Graphics 2 Controller
    # Flat Panel Display Support
    # Dual independent Display Support (incl. 2x LCD)
    # Up to 1GB PC2700/DDR333 SDRAM (incl. ECC)
    # 3x 10/100/1000 Mbps Ethernet
    # 4x USB 2.0, 4x RS232C
    # 1x ATA100 and 2x SATA150 IDE Controller
    # AC-3, SPDIF and Sound Blaster 16 compatible
    # Size: 170 x 170 mm (6.7" x 6.7")
    All I can say is Whoa! I wonder how much this will run...
    "I'm a dick!"
    "I must seek knowledge and it's bastard son truth" - The State
      From what I have seen elsewhere on the web, this cute little baby will run 450-700... yes, american dollars. So figure the super expensive Pentium M processor and you have a choice of a nice computer or just as nice of a car
      But hey, if nothing else, you have enough ethernet ports to network the tires and armrests together.
      I have found you an argument; I am not obliged to find you an understanding.
        I would be all over this if the board was cheap, i mean, believe it or not, you can grab a celeron M chip for only like $150, and they are only a few ticks slower than the Pentium M according to all the benchmarks. Just not worth it though to spend all that money on a motherboard thats just being used in the car. Unless of couse you have money to burn, then what the hell.
          why do you need 3 LAN connectors??? If they did a version with a couple of firewireisntead it would be much better.
            Then how about this.
            Commell LV-672
            Features
            CPU: Intel Pentium 4 with LGA775 @ 800 MHz FSB.
            Memory: 2 x 240 pin DDR2 533MHz up to 2.0GB.
            Chipset: Intel 915G and ICH6R.
            VGA Interface: built-in Intel Graphics Media Accelerator (GMA) 900.
            PCI Express bus: PCI Express x16 graphics delivers up to 4 GB/s per direction, 3.5 times more bandwidth than AGP8X.
            Enhanced IDE: one Channel support 2 ATAPI devices up to Ultra DMA 33/66//100 mode with data transfer rate up to 100MB/s.
            Serial ATA: Integrated Serial ATA controller facilitates high-speed data transfers at up to 150 MB/s for each of 4 ports. Supports RAID 0, 1 and 0+1 function.
            LAN Interface: Two 100Mbps/1Gbps Ethernet port by Intel 82541GI .
            Audio: Realtek ALC655 AC97 3D audio interface.
            USB: 6 Hi-Speed USB 2.0 interface with up to 480 Mbps of data transfer rate.
            IEEE 1394: 2 IEEE1394A ports with 400Mb/s transfer rate.
            I/O Ports: 2 serial ports, IrDA, FDD, PS/2 keyboard and mouse ports.
            Mini-PCI: 1 x Mini-PCI Type-III socket.
            Digital I/O: Supports 8 bit digital I/O.
            Watchdog: Software configurable, 1s.....255s / 1ms.....255 ms.
            You can get it here: http://www.bwi.com/scripts/site/site...ion/configure/
              Commell LV-672
              SNIP
              Sure $350 for the board,.... no way.
              TruckinMP3
              Read the FAQ!
                Just seen it on epiacenter.com
                From the specs it doesn't have any rivals...
                It has, and for the forst time, a 4x AGP port. It also has 2 ddr slots. Still 1 PCI slot though. I think I'd rather have 2 PCI ports, than 2 ddr slots.
                Anyway, far better that the Commell.
                Renault Megane...the OEM look
