CD drive caching
  • CD drive caching
    just playing around with MPXPLAY this week with CD full of MP3s and despite using various different CD drives;
    when I have one track playing, when I move to a different directory on the CD to see what track I want to play next the music with jump.
    I assume as the CD drive wants to read the FAT table briefly.
    I was wondering, is there a program for DOS that will cache the CD drive, by storing the FAT table of the CD in ram and boost the speed in changing different tracks?
    John H
    There are a number of things that could be causing this, I think...
    It could be something to do with the 'refresh' rate of your LCD, this only applies to character screens, or, your processor might be too slow...
    I had the same problem on my P75 with a 4X CDrom drive and a 40X4 lcd the problem was the refresh rate thing...
    If you aren't using am LCD, then, I don't know...
      You can try to run SmartDrive in DOS and tell it to cache the CDROM drive, but I'm not sure if SmartDrive will let you do this. Try typing smartdrv /? to find out the command line options. There may be an option to cache the FAT only...
        thanks skinnyboy,
        I havent got my LCD yet, the P100 has 16Mb of ram, BTW.
          If you don't have an LCD, then I probably can't help you...
          Unless you have the LCD enabled and don't actually have one connected???
            When you playing the MP3s look at the CPU usage if it anywhere near 90-100% then your computer is just to slow to handle any other processes other then playing MP3s.
            Caching might help so give that a try using the technic which Aaron specified
            System Comp V3 - In progress.
            Low power MB with C7 CPU, DC-DC PSU, car ECU link, USB TV, GPS, 7" TFT, Wireless, Voice.
              Also try running mpxplay, with the option to read id3 information on play, not load. using the -ini tag
              -ini don't preload file informations in playlist (header,id3tag)(load at playing)
              It may be that mpxplay is trying to read all the id3 tags in the directory as your browsing, dusrupting the streaming of the mp3 off the cd.
     Plans and progress on my install - (Updated 28 June 02)
              Australian mp3car Portal
              mp3car related links Check them out / Add some
              mp3car FAQ - RTFF
              [########==]80% Assembling
              -=Current Progress: Working Sproggy supply, building box.=-
                no I have no LCD drivers.
                MPXPLAY runs very nicely on the P100 Dell, I am using less than 20% of the speed.
                No CD drive in general are just slow, when I have a song player, when I play around changing directories, the CD drive wants to read the FAT table of the disk, interupting playback.
                I am pretty sure some kind of caching software would make it run nicer.
