Pentuim M on DFI Vs. Epia Worth it?
  • Pentuim M on DFI Vs. Epia Worth it?
    I have a conundrum. I have been delaying the install of my carputer waiting to save up for the right parts since august now. I finally purchased an Opus 150, Seagate HD, Panasonic slot load DVD/CDRW and Kingston 512 DDR. I already have my GPS, OBD and my albrite/controller/inverter, (which is a long story and for another thread, but going on the assumption that everything works out with the screen, I am almost there.)
    I still have to buy a motherboard. For months I was under the assumption that I was going to buy an M or MII epia, but kept holding off from purchasing it. I wanted to, but kept holding myself back. While I am sure that the epia is the smart choice for power consumption, size, low heat output, price and port availability. I also know from what I have read here that they are not the fastest boards either. I am not a gamer so I just assumed it would be enough for my needs in the car, and chalked it up to the sacrifice for the low power consumption.
    Then a couple of weeks ago came this
    And this was already around but the only board available was a super expensive ITX option that was way out of my league.
    But combined with one of the two new mATX boards it is under $500 dollars
    Hmmmm.
    So my question is who thinks it is worth it? There is a good 250-300 dollar difference between the epia and the Pentium M setup.
    The Pentium M 2.0 only consumes 28 watts at full load, I am sure the 1.6 will be slightly less, I cannot find info on how much power the DFI consumes only that it is listed on there site as “low power”. Form what I have been reading DFI makes a good board and a overclockers dream. I few reviews have overclocked the 2.0 M to 2.8
    I am especially curious to here from Epia owners in a “if I could go back and do it again light”. Knowing what you know now having had the epia what’s you take? If I decide to go with the Pentium setup it is going to delay my install yet again.
    Sorry this is so long.
    Thoughts
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
    Why not AMD Athlon Mobile?
    My combination cost about 190 (CPU 100, Asus mobo 75, + Tax S/H)
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
      MatrixPC, I was thinking about switching from my EPIA 800 to an athlon mobile setup. What model motherboard are you using?
      EPIA 800, DWW-7VGA LCD w/Touchscreen, 256mb ram, dvd rom, ati radeon 7000 video card, 80 gb 3.5" hard drive.
        I have the same setup as MatrixPC, Asus A7N8X-VM motherboard with a Mobile Athlon 2400. For me it cost less than MatrixPC, I was able to find the board for about $40.
        Installed
        Asus A7N8X-VM - AMD Mobile Athlon 2400
        512 Ram - 60GB HD - Opus 150w
        Lilliput 7" - Rikaline 6010
        [00000000000001100010-] 98% Completed
        Check Out My Install!!!
          Read below !
            I will look into the athlon idea... anyone running it with a opus?
            My Install
            Software:
            CFiG v1
            CarShell
            StopWatch
              You can you a 35watt Mobile AMD 2500+ at 1800+ (1.1volts) and it will use 25 watts of power. Plus these chips are MUCH MUCH cheaper than the Intels.
              My main right is a highly overclocked (watercooled) Mobile AthlonXP 2500+ running at 2.85GHz (~3800+) (as fast as a 3.88GHz Pentium4) 2.2volts. When I underclock it alot, I am able to run it at 0.8volts at 900MHz, and it uses about 16 watts.
              Here's a link to a 2400+ Mobile (35watt). http://www.newegg.com/app/ViewProduc...103-439&depa=0
              Underclocking it would be a very effective (and cheaper) solution.
                athlon Mobile suggestion seconded. Excellent processors and very robust. They come multiplier unlocked so you can give yourself a wide range of performance options. My desktop is running at 2.4ghz, but i've also run it all the way down to under 1ghz. In fact, if you use speedfan on a supported motherboard, it'll change your clockspeed on the fly, kinda like speedstepping for your car computer or desktop.
                Best of all, they work on a lot of existing socket platforms.
                Just make sure you get a mobo that supports undervolting; this'll help you run a lot cooler.
                Stealth OEM spyder
                1204 dot net!
                  Where did you get the mobo from?
                  My Celica Carputer Install
                    www.dumpinggoods.com
                    Installed
                      Thanks for all the reponses, will spend some time looking into the athlon mobile when i get home, girlfriend dragged me out shopping so I stopped in the apple store to read and post
                      But that does sound like a much more cost effective solution. I think the M is a great processor but if I can go AMD and it is comprible on power consuption and can be done with the opus I will go that route.
                      My Install
                      Software:
                      CFiG v1
                      CarShell
                      StopWatch
                        Yeah, I suggest Abit NF7-M (has onboard video; or ofcource the NF7-S if you plan to use a graphics card) with AthlonXP 2400+ 35w mobile. That shoud run fine with the opus.
                          how fast do these kind of setups boot? i'm looking for a new motherboard/CPU to run on my opus 150 and i'm looking for something that boots super fast, shortest BIOS/POST time and of course fast windows boot/hibernate times
                          Signature: [==||========] 20% complete
                            ATX form factor is too big for me, I intend on installing in my glove box. What do you think of of the VA-10?
                            Planning on useing the onboard video unless it causes problems, but I think with 512 RAM I should be ok. I dont think the voltages are ajustible on this board though, check my math on the power consumption though i think i should be fine
                            processor - 35 watts
                            seagate 7200 rpm <= 30 watts
                            dvd/CDRW <= 30 watts
                            figure on 4 or 5 USB @ 5 a piece - 25 watts
                            DDR RAM - 10 watts
                            I am up to 130 watts not counting the mobo and onboard video and audio.
                            Anyone know what the power comsuption usually is on mATX boards useing onboard video and sound?
                            thanks
                            My Install
                            Software:
                            CFiG v1
                            CarShell
                            StopWatch
