underclocking CPU w/ foxconn mobo HELP!
  • underclocking CPU w/ foxconn mobo HELP!
    My computer keeps freezing because I only have 150 watts to use and my CPU is a 2.4ghz p4. I have a foxconn microATX motherboard and it gives the option to over clock it but it only lets me put a value from 133 to like 266. I want to put it at 100mhz so I can drop the speed down to like 1.8ghz, does anyone have any clue how I can get this done? I read the manual and they didn't have any jumper setting for the CPU.
    http://pcclub.com/product_detail.cfm?itemno=A4801010
    yeps
    same problem here : P4 2 GHz = 58 Amps, that way my computer keeps reboting when i start it up.it reboot after the post (when the cpu takes power). I have also a 150W power supply and i'm thinking of inserting a 2 ghz celeron and no P4 because a celeron uses 43 amps instead of 58 amps, maybe that would help .
    ThE ScReW's CarPuter :-)
      I also just saw that your mobo is almost the same like mine, but mine is an FS51 from shutlle, also with the sis chipset who doesn't directx 9 !
      Chipset
      North Bridge SiS651
      south Bridge Sis962L
      Chipset Detail Spec
      CPU
      Socket 478
      Intel Pentium 4/Celeron
      478 pin package with 400/533MHz Data Bus Speed
      Soft configuration FSB from 100Mhz to 166MHz
      Form Factor
      Flex ATX
      Memory
      2 x 184pin DDR DIMM
      Support DDR200/266/333 un-buffer DDR SDRAM
      up to 2GB capacity
      Expansion Capability
      AGP Slot X 1 Supports 2X / 4X AGP Device
      PCI Slot x 1
      USB port x 4
      IEEE1394 x 3
      5.25 Reserved Bay x 1
      3.5 Reserved Bay x 2
      (TWo HDs or Singel Floppy + Single HD)
      Onboard Graphic
      Integrated SiS651 VGA
      VGA Memory cache up to 64MB
      VGA driver
      Audio
      Realtek ALC 650
      AC '97 v2.2 (supports 5.1 channel) compliant CODEC on board
      Support Digital SPDIF In/Out
      Audio Driver
      Onboard LAN
      Realtek RTL8139 Family PCI/Cardbus Fast Ethernet
      10/100Mb Fast Ethernet LAN
      Support Wake on LAN, Boot to LAN, PXE 2.0
      LAN driver
      USB 2.0
      Integrated SiS 962 USB 2.0
      Onboard 1394
      VIA VT6306
      Complies with 1394 OHCI specification revision 1.0
      Support 400Mb/s, 200Mb/s, 100Mb/s data transfer rate
      IDE interface
      2 x UltraDMA/100 IDE Channels Master from SiS962
      80-pin Cable Backward Compatible Legacy ATAPI Devices
      ATAPI IDE CD-ROM, CD-R, CD-RW, and LS-120 Supports
      What is LS 120 support ?
        Where are you getting that information on how many Amps the CPU uses? I keep seeing voltages not ampres.
          http://www.intel.com/design/Pentium4/documentation.htm
          Look into the datasheets and choose your proc Intel Pentium 4 Processor in the 478-pin Package at 1.40 GHz, 1.50 GHz, 1.60 GHz, 1.70 GHz, 1.80 GHz, 1.90 GHz, and 2 GHz Datasheet i guess you have to use this datasheet : same as mine.
          Open it and look at page 20
            Originally posted by ThEScReW
            yeps
            You mean watts and not amps right?
            GammaControl v2.4
            SKINbedder v3
            1995 Lexus SC300
              According to page 22 of ftp://download.intel.com/design/cele...s/29074802.pdf
              And page 20 of ftp://download.intel.com/design/Pent...s/24988703.pdf
              Both the Pentium 4 1.8ghz (50.4A) and Celeron 1.8ghz (50.4A) = 78.624 watts
                And page 20 of
                Yeh, usually processors are measured in watts and not amps. Well, atleast in the overclocking world
                GammaControl v2.4
                SKINbedder v3
                1995 Lexus SC300
                  I mean that celeron on 2 Ghz: ftp://download.intel.com/design/cele...s/25174807.pdf
                  And now i have that pentium 4 on 2Ghz :
                  so that's 57.4 A and 43 A for the celeron
                    Look on page 83 for the celeron... it says 52.8w. Watts is also better for measuring draw because power supplies are measured in watts and not in amps.
                    GammaControl v2.4
                    SKINbedder v3
                    1995 Lexus SC300
                      indeed nice and the p4 uses 75 watts
                        If you think that's alot look at the Presscot processors 1 presscot processor would bring a 150w Opus to its knees
                        GammaControl v2.4
                        SKINbedder v3
                        1995 Lexus SC300
