window tint on lcd?
  • window tint on lcd?
    I'm unable to adjust the gamma or brightness on my laptops LCD. Has anyone considered purchasing a roll of cheap window tint and cut it down to size and stick it to the lcd? Does anyone see any reason why that will not work?
    thx
    Just wear sunglasses!
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
      Maybe get a new videocard? Did you try GammaControl?
      PowerVoice v1 | NaviVoice Source
      GammaControl v2.4
      SKINbedder v3
      1995 Lexus SC300
        I did try GammaControl I can't get it to work with my laptops video card. The manufacture doesn't provide w2k drivers which provide gamma control on the driver.
        It's a great program I wish it worked on my setup.
          What kind of laptop do you have? Find its specs and then download the drivers for that video card. Not all manufacs update their driver pages.
          GammaControl v2.4
          SKINbedder v3
          1995 Lexus SC300
            I have a Toshiba Sattallite Pro 470cdt witha Chips on Technologies 6555 chipset. Toshiba never made a w2k driver and the MS drivers do not seem to allow me to do gamma control however period. The original manufacture 'Chips On' has a 2k driver which has a gamma feature in the display properties applet however It simply will not work right my with laptop. =(
            I purchased a 5pk of transparent/colored plastic dividers from Avery which seem to be working well. I'm going to get it cut down and install this weekend.
              Did you try to run one of the front ends around here. These programs have a dimmer. And at one time, there was a program on the mp3car software section (not the forum one), that did just that.
              Renault Megane...the OEM look
                Yeah, I agree with Cris. The reason why a lotta' people use MediaEngine http://www.mediaengine.org It has an auto drimmer function, that you can set for whatever time to start or stop. Plus, if you need more than just that, you can also tell to change to a night time type skin (black), that reduces brightness also.
                I'm sure you already tried this, but have you tried using your function brightness and/or contrast keys? Some laptops have software built-in that can control brightness, so maybe you're using that and not realizing you've got hardware brightness control. But assuming you've tried that, try going into your BIOS (restart and go into your laptop's "setup"). I don't know about Toshibas, but some laptops have BIOS options for brightness. If you're laptop's just gotten into a "funk", turning brightness controls on or off might knock it outta' it's funk and give you control back. Now one word on laptops... programs that can "dim" the brightness of the screen like MediaEngine are fine, but most laptops (like Pocket PCs) will still produce the same brightness even with a black screen, due to the way they're backlit. (that's why hardware brightness control is so important to my GPS Pocket PC) Hope this info helps.
                  I've tried just about everything.. afaik this model only has gamma adjustments in the driver an no function key. The avery transparent colored divder has helped a lot but it's still not dark enough.
                    if you can hunt down a red tented plastic it would do the job for you
                    FEEL THE RUSH
                    P4 1.7, 1gb sdram, 40gb 7200, ati dual video, 5.6" In dash, 13" lcd touch screen in back.
                    96 gt conv. Mustang
                      I think that MediaEngine also uses Gamma to dim the monitor. There is this program out there that will act like gamma but it isn't really. Search for gamma and you'll find it. It places a semi-transparent box on the screen that you can click through. I did find that it slowed down my computer (a 2.5ghz p4 with 1 gig of ram and ATI 9200 (probably its fault )).
                      GammaControl v2.4
                      SKINbedder v3
                      1995 Lexus SC300
                        Used to work for Toshiba, see if there is a nt4 driver or win98. I was never happy with driver update support/developement. Do you have the toshiba utilities installed?
                        http://www.csd.toshiba.com/cgi-bin/t...ceghdgngdgnn.0
                          man i had the prog now lost it. search the threads for i think its called fader.zip or dimmer.zip
                          its a simple touch to dim screen 3 or 4 shades works great just need to find it.
                          found one just search forum and found this. just tried it works good.
                          http://www.mp3car.com/vbulletin/showthread.php?t=14560
                          CAR:2001 Ford Crown Victoria
                          PC: Acer EEE 900HA with Win7 with CF 2.0.
                          Memory:1G
                          Drives:160gig
                          WI-FI:Cingular
                          GPS:IG2k9
                          Screen:Xenarc 700TSV
                          The Florida Meets Thread
                            Also... to anyone thinking about tinting; let's say you find some kinda' tint for your laptop / tv / whatever. And you're bangin' with it at night, and it's workin' out great. The ladies are all givin' you the eye in your hot ride at night 'n' crap. Ok... day time comes the next day. How the 'freak are you gonna' see that baby in direct (even indirect) sunlight?? If we're talking about a laptop, then I know for a fact that all laptops will look like their screen goes black in direct sunlight. Tinting is the way to go... ONLY if you're gonna' be using it at night, strickly.
                            Go with the software brightness controls. The only way the tinting thing would work is if you had a monitor with a transflective screen, like Pocket PCs, cell phones, ect. As far as I know, there are ZERO transflective monitors or laptops.
                              But in order to apply a layer of film, you have to spray the screen with pretty much water...
