Playing mp3z with the engine off?
  • Playing mp3z with the engine off?
    How long could I expect a PC based system to run on a fully charged battery while the car is parked? Please post your experiences with this.Thanks
    Honda CRX. Custom enclosure.
    Supermicro SED MB (Onboard sound and TV-out). Celeron 700. 64mb ram.
    40 GB Seagate HDD on vented foam mount.
    Keypower DC-DC KP-DX 250H ATX 250W.
    Delvcam 5.6" TFT LCD Monitor.
    Old headunit (ripped out tape mechanism added audio inputs on back).
    X10 RF mouseremote.
    "Wired Ride" web site
    The Australia/New Zealand mp3car Portal. Join now!
    I can't say I've tried it but with my inverter (100W) the manual says, that you sure run the engine for 10-20mins every 3-4hours to stop the battey going flat.
    But just in case the inverter has an auto-shutoff, when the battery is starting to go flat it makes a beeeeep noise for 5mins and if the engine hasn't been restarted the inverter shuts down to leave enough in the battery to restart the car. Neat!
      Man.. it'll last for ages with just the computer on.. I mean, its probably drawing at max 100W.. which is like not even an amp at 110V..
        As a general rule, it takes 10-20 minutes of driving to recharge a battery. Also, in most cars you can leave your headlights on for at least an hour or two before your battery dies, and I'm quite sure your car player will draw less power than that.
        digitalswirlee.com
          But one amp on 110 volts is about 9 amps in 12 volt out of battery.
          Head lights are typically 50-60 watts each so leaving them on is pretty much same as playing mp3s with low volume, if your sytem takes like 100 watts. Plus if you are using inverter you can add some additional as power loss in transfer 12-110-12.
          sj
            Yep.. good point.. 9 amps at 12V..
              mine runs overnight when I forget to turn it off!!! :-))
              GrahamS
              www.mp3uk.freeserve.co.uk
              GrahamS
