Need some electronics help
  • Need some electronics help
    Im making my IR receiver right now, I was supposed to get a 100mA 5V regulator. But I could on find a 1A 5V reg
    http://www.radioshack.com/product.as...%5Fid=276-1770
    will this still work?
    come on where are the EE's? :T
      1A 5V is more than enough, there is no regular that's rate for that little current.
      2006 Camry
      Compaq Laptop
      Holux GPS Iguidance 3.0
      7" Xenarc Touch Screen
      Carnetix 1900 Power Supplied, Wireless b/g
        It will work just fine.
        Want to:
          1 amp could end up roasting it
          What is it for? 1000Ma or 1 amp could end up roasting it depending on what it is.
          Squid has a nice regulator circuit HERE that I have used extensively for my PSU needs and it works great mine is set at 9 Volts (adjusting R2) and 200Ma (Via R1) and yes you can go that low in amps.
          In the schematic you would need to replace R1 with a resistor rated at 1 watt and the value would need to be some where between 9 and 10 Ohms to output 100Ma use a multimeter set to DC AMPS to ensure it is really outputing 100Ma or close to it.
          In progress Carputer [////////||] IWill ZPCgx: P4 2.40Ghz, 512Meg, 40Gb, Xenarc 7" TSV, 5 1/4 slot DVD, 802.11g DWL-G132, Ebay BU-303 USB GPS, TMobile GPRS Internet, Custom made power controller.
          HU-Alpine CDA-7897 Fantom Face XL AM/FM CD/MP3 Receiver.
            its for my IR receiver
            they didnt have 100mA 5v so I figured I should get the 1A 5V and see what you guys think.
            heres the schematic if it helps anyone come to a conclusion for me:
            http://www.lirc.org/images/schematics.gif
              It shouldn't, unless I've got my electronics mixed up. The voltage is akin to water pressure. Essentially, how fast the power can move. The amperage is the amount of electricity that COULD move, kind of like the diameter of the hose.
              In this case, 1 amp is not how much power moves when you hook it up. It's the maximum that COULD be supplied if the electrical device demanded it. In this case, it only needs a very small amount of power.
              It won't fry it. What would fry it is if you got the wrong voltage, not amperage.
              Want to:
                yes that sounds right, but if the amps are too high will i need to provide more power? using the anology it like using a huge pipe for a few drops off water. would it matter?
                  This type of circuit is getting power from the serial port so you are only dealing with MA in this case.
                  The circuit I showed you does not apply to this.
                  You may be able to use the a standard 7805 or you can order what is shown in the schematic and any other parts you may need from Mouser HERE or Digikey
                    You should be able to buy the 78L05 regulator everywhere. If you can't find any place that sell them, PM me your address I'll send you one for free only if you are in the States. I bought a bag like 5 or 6 of them for a buck 50 and only use 2 or 3.
                    I am not sure if you can use 7805 because the serial port may not be able to supply enough power for it.
                    Your other option is check this guy out http://www.cesko.host.sk/. He is the author of the plug in you are going to use with Girder. He use a 5.1Volt zender diode instead of the 78L05. His circuit and the LIRC circuit is very similar.
                    Y2K Accord Dell GX150
                    EmoRebellion is a SCAMMER
                      No problem. The analogy only goes so far. A milliamp is 1/1000th of an amp (.001) 100 milliamps is .1 amps. Your device can supply 1 full amp if necessary. But it won't be. You're fine if you go with this method.
                      Want to:
                        thanks
                          Not to sound obnoxious but I am an electronic engineer and a device will only draw as much current as it wants. If you had a device that draws 50mA, you could have a 10000 amp regulator (if such a device existed) and your device will still only draw the same amount as with a 100mA regulator.
                          Ohms law states the Voltage(V) = Current(I) x Resistance(R). Therefore I=V/R. In simple terms the amount of current that a device draws is based on it's internal resistance. So you can see that if you are not changing the input voltage or the internal resistance there is no way for cyrrent to increase.
                          As long as your regulator can supply MORE current that your device then you are fine.
                            Another simple explaination that might help is that you can have a 12volt plugpack in your house that can supply say 1Amp. You also have your 12v car battery that can supply a couple of hundred amps. A device that works fine with the plugpack is not going to blow up just becuase you connect it to your car battery, it will be fine.
                              What is it for? 1000Ma or 1 amp could end up roasting it depending on what it is..
                              Rubbish!
                              [QUOTE=Deviser]
                              Rubbish! - you clearly dont understand what you are talking about!
                              How about we post good info for people who need to know, not information that is partially or compeltely incorrect!
                              (Rant/flame over)
