no windows shutdown options
  • no windows shutdown options
    i cant find my settings that says..
    if i press my power button do this... and i need this for my opus to work.
    why isnt there anything in my power/advanced settings??
    mick
    View My Blog
    Click for 2GB FREE on-line storage!
    mick
    Go to the display settings. (Right click on your desktop and select Properties)
    Go to the screen saver section.
    Click on Power.
    1999 Plymouth Voyager (That's right, big-pimpin' in a minivan.)
    PC built into console
    worklog with pics: http://www.mp3car.com/vbulletin/showthread.php?t=46359
    Some of my music: http://www.myspace.com/markquestion
      or enable it in your BIOS
      go into your BIOS and find power management or savings or something to do with power and enable it there
      Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
        question: i know where is should be.. but the setting aint there..
        sascooby: i'll have a look around the bios now..
        thanks
        View My Blog
          Installed.
          -GPSSecure- - GPS Tracking
            Never heard of a MB having the option of hibernating/standby/shutdown/reseting your computer when the power button is pressed if this is what the OP was referring to.
            Installed.
              i had a look around the power settings int he bios but i couldnt see anything.. i cahnged a few things but it made no differance.
              brandy: thats what i wana see. but this is what i got.
              View My Blog
                Go to the Hibernate tab and make sure "Enable Hibernate" is checked.
                Also, open system properties (Shortcut to get there is windows key+pause/break), then go to Hardware, and device manager. Then open up system devices and take a screen shot of those.
                  Most PCs built in the last 5 years have this.
                  [H]4 Life
                  I'm a lesbian too.
                  I am for hire!
                    make sure you have the chipset driver installed for your motherboard.
                      Open device manager. What do you see here ?
                      [H]4 Life
                      I'm a lesbian too.
                      I am for hire!
                        ok this is making sence now..
                        under computer in my device manager, i just have "standard PC"
                        ok next questions.. where would i find this to install it??
                        thanks heaps all of u's. ive got 2 pc's with the same problem.. and another one has it and ive never been able to understand why
                        View My Blog
                          Ugh...I was just trying to change a friend's motherboard and I stumbled on the fact that Windows XP is a ***** with APM.
                          Correct me if I'm wrong, but if I remember right, once you install Windows XP, it isn't possible to change the power management (unless you reinstall). It has to do something with the fact that it is too deeply integrated into the OS.
                          You have to make sure it is enabled in the BIOS before you install Windows, otherwise you'll get that "Standard" business.
                            Odd, just checked both the Shuttle MB I am using and the other computer near me which has a BioStar MB and neither of them have this option.
                            Installed.
                              I bet it does. Look in your bios for APM or ACPI.
                              They needed to be enabled when you installed windows.
                              [H]4 Life
                              I'm a lesbian too.
                              I am for hire!
