Inverter auto power-off on low battery
  • Inverter auto power-off on low battery
    I have a Tripp-Lite 300Watt inverter that claims to automatically shut off when the battery drains to a certain point.
    Has anyone tried leaving the unit on to test this? I know it has alot to do with the battery, but can you start the car after the inverter automatically shuts off?
    If anyone has tested this with a Tripp-Lite or other inverter, I'd appreciate to hear your findings!
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    Check the manual on the triplite for the cut off , I have tested it with some other bateries, and its usualy around 10.5 - 11.00 Volts. I know my car will crank with 10.0 left in the batery.
    A good service center / batery shop will have a load generator. find out your target voltage, then use the load generaor ( along with your headlights, and AC to run the car down to the target voltage, then try and start it. if it wont start, run back inside and tell the guy you need a jump
    Gizmo-
    Techonlogy on Wheels
    http://www.hjnetworks.com/car
