J-Link pinout
  • J-Link pinout
    I know this topic has been beat to death, but has anyone found a pinout for JVC' Jlink connector? I have a Pioneer changer that I want to hook up to my JVC head unit. I've found the pinout for the changer. Maybe some one could help me figure it out from the back of the hu?
    i think that this will help
    I test it and it works on my JVC with no problem, you just must set on your radio to "line-in"!!!
    I was born brilliant, but education ruined me!
      Damn i really need one of those connectors for my my sony.....(JVc same connector as sonny and alpine but different pinout)
        have looked here
        http://www.cableuniverse.co.uk/catal...ain_page=index
        for your plug, no joy, but its a good place for plugs and cables that are hard to get. So ill'e post it anyway.
        EPIA MII: 512m Ram: LinITX 8" Touch Screen: Carnetix P1290 PSU: 802b PCMCIA Wireless card: Slot DVD Player: Touchpad: Wireless Keyboard: BU303 GPS Mouse:
        Win 2000: RoadRunner Front End: Michelin Mapstore GPS: Netstumbler:
          is that to connect your JVC changer to your Sony head unit?
          I noticed you're using a laptop, same as me, and I've also got a Sony head unit, I bought an XA-300 to connect my laptop to my headunit, you thought of that?
            NO NO NO NEVER connect a JVC and sony together - they have different pinout (did you not read my post) and different language. (Unless anyone knows otherwise i am pretty sure this will screw up you stuff if you try)
            thefreak, i was planning on using the lappy but as my sig says i am dumping it and going mobile athlon. It is a shame as i have loads of docking ports etc for my lappy and upgraded the ram and put a nice install of XP on but i cannot get 800x480 res so will buy a new PC - +I like using my laptop for my work.
            The reason i want the cable is to link my PC to my headunit via a unlink cloning box. This fools the sony (with CD/MD changer control) into thinking that a changer is attached by sending a timing signal from a pic and then it also allows you to controlt he pc from the HU and the HU to display track info. I was gonna go with an amp but don't want to lose the ability to just turn the radio on with no pc running.
            EDIT: i believe the box you have does the same as wht i am building but i will have the PC-HU data link for track changes and info and it should cost me about 20 to make including cables
            H8tred666 look up some of the Sony unilink stuff as i believe i have seen a pinout for the JVC on one of those sites. Will have another look now....
              try here - forum might be big help:
              http://www.mictronics.de/?page=j1850_vpw
                Any idea what the rest of the pins are? The Pioneer has 11 pins, 10 of which are in use. The JVC has only 8.
                  So you could simply make a line in by using the pins 6, 7, and 8?
                  Carputer Status -> 85%
                  Carputer Planning -> 100%
                  Blauvster's Carputer
                    you can change the resolution with a third party app
                    called powerstrip
                    http://www.entechtaiwan.com/util/ps.shtm
                    additionally with this there's a setup text file that you can put in your custom screen resolution if you dont see it with default settings in powerstrip
                      Hi There,
                      I`m looking for the Unilink pinouts for sony to use as aux input.
                      Could someone help ?
                      Thanx
                      Suv
                        A real handy website to check out is http://pinouts.ru/ . They have pretty much everything.
                          J-link updated pin out
                          I know it's a late update to this thread, but it took me long enough to get the information too. Pinouts are from the labelling on the board itself. I'll be connecting up my cd changer direct this week and will post back when it's all working.
                            Were you able to get this working with this pinout?
                            1996 Suburban
                            4- 5 headrest TV monitors
                            1- 7 touch display for driver
                            3GHz computer w/ 2 video cards
                            1 video for the 4 monitor 2nd video for the driver
                            2 sound cards
                            1 sound for the 4 monitors 2nd sound for the driver
                            2 XBOXs
                            2% done
                              Works fine
                              I didn't have any connectors laying around so i opened up the unit and did some soldering
                              was a little trickier with all the weird kameleon motorization and such
                              any q's on the process - post me!
