A-Tech 5000 HP Media Center Case
  • A-Tech 5000 HP Media Center Case
    OK, this is slightly off-topic in that it wouldn't go in your car, but it's still worthwhile to look into for a case to build a Home Theatre PC in.
    A-Tech Fabrication has an all-aluminum HTPC-style case that has some really cool options:
    • Front-mounted Xenarc 700TS LCD touch-screen display.
    • Front-mounted character LCD display.
    • Front-mounted Griffin Powermate USB dial controller.
    The case starts at $395, though, and a fully decked out case will run you about $1000, and that's without the $400 Xenarc 700TS.
    See here:
    http://www.atechfabrication.com/products/atech_5000.htm
    http://www.atechfabrication.com/atec...order_form.htm
    This case has a lot of options in common with a CarPC..
    Nice.. and expensive!
    very nice!
    I absolutely LOVE the aircraft grade 6061-T6 heat-treated aluminum alloy!!!!
    I might have to put this on my wish list!
    Jan Bennett
      Originally posted by Red GTi VR6
      very nice!
      The coolness doesn't stop there, either..
      Check out the REST of their HTPC cases:
      http://www.atechfabrication.com/HTPC_cases.htm
      The Mass Storage Case at the bottom is especially cool (pun not intended), it's an external 1U-size hard drive case that is passively cooled, and can hold 4 hard drives.
        why don't you just show then the best of the best
        http://www.atechfabrication.com/prod...en_display.htm
