Need quick measurement on M10000 board
  • Need quick measurement on M10000 board
    If anyone can help out, just need a quick measurement on the M10000 board...
    - The specs say 17cm x 17cm, can anyone give me an exact measurement?
    - Also, how far does the monitor input stick out off the board?
    Thanks,
    Matt
    2004 WRX Carputer
    sorry, don't have the exact measurements offhand, but i remember it was pretty close to spec. One thing you WILL have to account for is the size of your cables coming off the board. If your monitor or USB cable headers are long (which they most likely will be), they're gonna cause you problems when doing the install. I had this problem when I was mounting my box; i didn't account for the monitor and serial cables to stick out so much.
    The monitor d-sub input sticks out about 1 cm from the edge of the board.
    Check out my sig for some images.
    Best of luck.
    Stealth OEM spyder
    1204 dot net!
      Check out the "Operating Guidelines" document at http://www.viaembedded.com/product/D...therboardId=81
      System status: in progress
        Yep, 17cm x 17cm x (approximately height of your RAM)...
        This is the most important when fabbing your own case.
        Caputer Mk. II
        '02 VX Holden Commodore Series II Executive
        MII12000, 512MB RAM, 60GB HDD (5400rpm), 16X DVD, TS200V
        Morex 60W DC-DC, Custom S/SDC
        OS/Software: Developing...
          anyone know where to get some 90 degree vga adapters?
            i'm pretty sure you can google for em
            Stealth OEM spyder
            1204 dot net!
