Five stupid newbie questions I had to ask.
  • Five stupid newbie questions I had to ask.
    Ok so the holidays are over and I have been putting off my carpc project long enough. I am ready to start ordering parts and have my list here but I had some questions about some of them.
    Please take a few moments and help me out. I would like to order parts this week.
    Motherboard: Going with MicroATX instead of Mini-ITX for compatibility/speed reasons.
    A) ASUS A7N8X-VM/400 NVIDIA nFORCE2 400 CHIPSET ULTRA ATA133 MICRO ATX FORM FACTOR 1xAGP(8X)/3xPCI/2xDDR W/INTEGRATED VGA,LAN,USB 2.0 & AUDIO (CPU TYPE:AMD DURON, SEMPRON, ATHLON XP - 266/333/400Mhz) - $79.00
    Question #1: The nForce2 chipset, does it support the illusive 800X480 resolutions without having to use powerstrip? I see in the drivers settings you can set custom resolutions. Can someone please confirm success?
    B) AMD ATHLON XP MOBILE 2400+ 45W (AXMH2400FQQ4C) - $76.00
    Question #2: Does this cpu work with above motherboard? Just wanna make sure. I am second guessing myself.
    C) Crucial 512MB's DDR400 $74.00
    D) FUJITSU 2.5" 80GB MHT2080AT 9.5MM 4200RPM 2MB - $143.00
    E) Notebook HD to IDE Converter 2.5" to 3.5" - $9.99
    F) Panasonic CW-8123-B Slimline Slot Loading CD-RW / DVD - $96.00
    Question #3: If I am mounting this inside my center armrest console thing so that the slot faces the rear seats, how do I connect this device to the computer that is in the trunk of my car? What cables do I need for it and where do I find them and what are they called??
    G) Xenarc 700TSV - VGA Monitor with touchscreen and video inputs - $399.99
    Question #4: What type of cable do I run from the computer (in the trunk) up to the above monitor? What is it called and where do I find it?
    H) IOGEAR MICROHUB 4-PORT GUH275 USB 2.0 HI-SPEED - $16.07
    Mounting this below the dvdrom drive for connection of any usb devices.
    I) M1-ATX Powersupply $74.99
    Question #5: Does this have enough power to supply above components?
    If not and you are going to tell me that I need the 150wt Opus, then my next question 5b: Are there any compatibility issues iwth the opus and this setup? I'll of course need the shut down and start up controllers working etc.
    I hope instead of just flaming me with and responses, you experts can just throw me a bone here. I am really just trying to get some or some 's before I put this all on my check card.
    Thanks in advance and I'll thank you again later!
    -Mike
    P.S. Question #6, Am I missing anything that I should add to my list? Any must haves?
    For the dvd drive: I am using a mapower external case molded into my center console...you can see pics of the process in my sig....
    do a search on newegg.com for mapower, a few will pop up, just look for the slim one...it will use USB for signal and a 5v ac power plug (which you can splice into the 5v rail on the M1....which is what I will be doing....
    the monitor comes with the cables that you will need....if you need extensions it will be a VGA extension and a USB extension.
    Hope this helps!
    Jan Bennett
      Only thing I would do different would be to change from a 2.5" hdd to 3.5" hdd. You could buy two desktop drives for the price of the one laptop, and have more speed and space anyway. What I did was buy 2, and get my system all set up how I like it, then ghosted it to the other drive just in case.
      Tidder
      Try RevFE
        I will agree on the hdd thing, but there are people on here who will disagree with it as well....think it's all personal preference and how much space you really need
        Jan Bennett
          You will need a VGA extension cable for the video and a USB extension cable for the touchscreen. Power too, of course but I assume you're supply that from some point in car that may not require an extension.
          I looked for that drive at NewEgg and found that it is an ATAPI/E-IDE. You ought to be able to use an ATAPI to USB converter cable here: http://www.newegg.com/app/viewproduc...118-401&DEPA=0
          I notice you left out a keyboard and mouse but assume you are counting on touchscreen, yes?
          I can't answer the processor and power supply questions. Good luck with your install!
          Want to:
            I thought I read in some other posts that the particular motherboard in question has had some weird problems detecting those Athlon's.
            They did a wire trick on the CPU to overcome it.
            Other people went to the BIOSTAR.
            As far as the PS goes, I read someone had done it with a mobile, although YMMV.
            Perhaps someone else could shed some light one this...
            -Mario
              Bumping my thread for a new day. I have not placed any orders although I did find a bluetooth pci card I think I may use instead of the usb adapter type. That way I can use my cellphone for internet.
              M3rdpwr: Thanks, I'll check out some biostars.
