VGA went out when I plugged serial in
  • VGA went out when I plugged serial in
    I plugged a serial port OBD2 reader into my computer and now the VGA don't work. I have no idea if the two things are connected, but they happened at approximately the same time.
    The monitor flashes teh NO VGA SIGNAL message when I plug and unplug the monitor cable, but enver gives a picture. The monitor is in workin gorder.
    Thoughts?
    Here it is! My carputer install! 1997 BMW M3
    Try going into your bios and change the resources for the serial port, maybe they are conflicting?
      That's what my roomate and I came up with too. But we can't even look at the bios because there is no VGA output. Nothing comes up on the screen at all. No windows, no bootscreen, no bios.
        So even if you remove the serial cable there is no still vga signal coming through??
        Caputer Mk. II
        '02 VX Holden Commodore Series II Executive
        MII12000, 512MB RAM, 60GB HDD (5400rpm), 16X DVD, TS200V
        Morex 60W DC-DC, Custom S/SDC
        OS/Software: Developing...
          Nope. Took the serial cable out and it doesn't go back to normal. Brought it inside and can't get it work on the desktop monitor either.
          Everything about it SOUNDS normal. Harddrive spinup, CD drive doing it's thing, but no picture.
            prebuilt or homebuilt odb reader?
            肚子笑痛了
            S60 Install
              Prebuilt. I emailed the company that made them. They say they've sold thousands of them and never heard of this problem.
              We're thinking it's a bios conflict but there's no way to check it. I tried to reset the bios but that didn't do anything.
                if it's a irq conflict it should go away when the serial cable is removed if not clear it by removing the battery for a few minutes with the power off to clear the cmos, or if the MB has a cmos clear jumper.
                doh!, read post then reply
                肚子笑痛了
                S60 Install
                  Could the serial connection have shorted something out?
                  I'm using on board video card on a mini-ATX and the serial port is right next to it.
                  By the way, I don't think (I'm not certain) that the first time I started it up after plugging int he serial cable that I saw a bios screen. I'd think if it was an IRQ conflict that teh bios would run like normal, realize there wa a conflict, THEN stop working. Like it'd have to know there was a new device first to assign that device to the same port at the video.
                  Let's assume for a minute that one of a couple things happened. I shorted out the VGA connector and fried the onboard video somehow. There's an IRQ conflict. Aliens have taken over my computer in an attempt to control our society.
                  If I got a cheapo video card tommorow and plugged it in, would this solve the above problems? (Assuming the aliens aren't good at screwing up computers)
                    Long shot here since you don't have an Epia board but this same type of thing happened to me and it turned out that the output of the board somehow switched to the TV output rather than the VGA. I booted with the TV into the Bios and switched it back. Worked fine after that.
                    I know you have a mini-ATX so I don't even know if this is a possibility on your board but if it helps, it helps.
                    Want to:
                      I have a TV card, but I'm pretty sure it's input only. I'm going to Best Buy after work and pick up a cheapy card and see if that cures it.
                        Try resetting the bios using the jumper on-board - you never know!
                          Did that yesterday as described above.
                            yeag best option is buy a cheap card - was gonna suggest it but you already thought of it. May as well get a board you know you can get native res with!
                              How much would a board like that cost? I'm not ultra concerned with getting native resolution as I don't find the lilliput to be THAT distorted at 800x600. Plus I figure if it's squishing a larger picture into my smaller screen that I'm seeing more than I would at 800x480. On iGuidance at 1000ft zoom I figure I might lose 1500 - 2000 ft of on screen mapping by going to the 800x480.
                              But....it'd be nice to have the option in case I changed my mind. How much would a VGA card that oculd do a thing like that cost? And could I find one to put in a low profile case?
