s video
  • s video
    Can i cut up a s-video cable and reduce the length of the connector and still have it work?
    Thank
    Core duo
    1tb harddrive
    256 ddr
    8 lilliput
    bu-353
    still installing...
    I wouldn't recommend it, unless you like splicing very thin wires.
      Nonsense! There are 4 wires in an S-Video cable. With a little care and touch you could easily shorten your cable just fine. Chop off a section of wire and match the colors to re-merge them. Or, get a new interconnect from your local electronics supply store and use that.
        It could cause you some interference/bad signal strength. I'd not recommend it, but your call.
        CarPC install is starting to come along again...
          I second greyscale...don't do it!
          Kimi ga kawareba, Seikaimo kawaru!
            I wouldn't splice if possible.
            Buy a high quality connector, cut the wire, and solder the new connector on.
            If you aren't good at soldering, get someone else to do it or give it a miss.
              grAyscale
                A long as you take care to keep the individual wires the same length, you won't have issue with bad signal strength (you aren't lengthening the cable, afterall). Interference however, could be an issue as Grayscale pointed out. To combat this, simply get a shielded interconnect from Radio Shack and use that instead of the old cut off one. I would challenge anyone to find a meter-able or noticable difference in signal output this way.
                  i will try it and if i dont like it will just throw it away.
                  Thanks for your knowledge
                  Core duo
                  1tb harddrive
                  256 ddr
                  8 lilliput
                  bu-353
                  still installing...
                    lol in all the technical thought, I think I've forgotten that this entire 'experiment' will cost all of $5. go for it and let us know what happens
