where to buy slim line cd-rom cables?
  • where to buy slim line cd-rom cables?
    i ordered the adapter, but i need the cable also where can i get it from , thanks
    01 blazer, LS1 engine, TR 220/220 cam, vig 3200 stall, 5.3 stage 1.5 ported heads, titanium retainers, APR harden push rods, dual X magnaflow 2.5's
    Interior: AutoMeter ultra lite's, panasonic cq8100u, kicker 8" L7's, kenwood 800 amp, PS/2,
    What kind of adapter is it? Slimline to IDE? If so you'll just need an IDE cable. If you don't have some laying around then the only place I can think of locally is a ratshack.
    My Install Thread
    digitaljetta.com
    MKIV VW Jetta
    How do I get sound to my car?
      As PPGT94 said, it should be just a standard IDE ribbon cable. Check for a picture or details from where you ordered it from. Most also use a floppy power connector for drive power. If the drive won't be within 18" to 24" from the motherboard then think about a IDE/USB adapter.
      Rick S.
      XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
        Slimline CD to IDE adapter 12.7mm this is what i ordered, so i guess that adapter just plugs right into the back of the cd-rom? and i dont need a cable?
          The black connector shown will plug into the back of the drive. It has the power and data pins all in one. on the bottom side is the standard 40 pin header connector for a standard IDE cable and a separate floppy drive power connector which powers the drive through the adapter.
          Rick S.
