HP Laptop Processor
  • HP Laptop Processor
    I may be able to get a laptop from a family member with a broken screen for free. It is an hp ze4325us laptop. The specifications says that the processor is an AMD Athlon 2000+ 45w. Is this the same thing as the mobile athlon processors? Could I use this processor with a micro-atx board for my carputer?
    EPIA 800, DWW-7VGA LCD w/Touchscreen, 256mb ram, dvd rom, ati radeon 7000 video card, 80 gb 3.5" hard drive.
    The CPU should be the same. It will have a smaller heatsink and heat transfer tube on it that will need a standard hs/fan. What's wrong with leaving it in the laptop case and hooking up your existing screen to it if everything else works?
    Rick S.
    XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
      exactly. then you have an onboad battery to take over in voltage drops and can do direct DC to DC convertor.
      "If it works this good why F with it?" -KMFDM "Intro"
      Strive for ethical wardriving: http://faq.wardrive.net/
      My CarCPUs: v1 - 2000 | v2 - 2004
      Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
        I thought about that, but this is going in a show car so I want the install to look good. I already have an opus 150 and everything else needed for the install. All I need is a motherboard. I'm either gonna go with the Biostar motherboard or go with an ASUS board and do the pin mod. If emailed opus to see if I can RMA my power supply to get it to work with the Biostar.
