PCI or USB notebook PC card adapter exist?
  • PCI or USB notebook PC card adapter exist?
    I've been looking on and off for several months for a notebook PC card adapter. I basically looking for an PC card adapter so I can stick wi-fi/CDMA cards into for a desktop or in like an external bay drive.
    why do i want this? my gf's work has provided her a Verizon Wireless CDMA notebook PC card with unlimited wireless access. she cannot afford to pay Comcast broadband their $45/month for access, and her work provided her this card for her work laptop, but she would also like to use it in her desktop. I saw such an adapter a LONG time ago, but can't find it.
    I also know some PCI cards are basically notebook PC cards in an adapter, but I have no knowlege of which ones will let you pull this off.
    any help would be appreciated:-)
    "If it works this good why F with it?" -KMFDM "Intro"
    Strive for ethical wardriving: http://faq.wardrive.net/
    My CarCPUs: v1 - 2000 | v2 - 2004
    Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
    If you are looking for a simple PCMCIA to PCI adapter, you could use
    http://www.tigerdirect.com/applicati...&sku=C250-3746
    this was just a quick Google find, but you may find a better price somewhere else.
      Newegg has 3 different ones it looks like and they are much cheaper. the cheapest being this one:
      http://www.newegg.com/app/ViewProduc...124-021&depa=0
      Hope this helps
        Check the specs on the PC card and the adapter you are thinking about getting. All adapters are not the same. If your PC card is a CardBus/32 bit device then make sure your adapter is the same. Go with a 32 bit one as it will work with 16 bit cards as well. That Newegg one should be fine though.
        Rick S.
        XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
          I hope I am wrong, but, I read here somewhere that wireless cards do not work reliably in PCI adapters, I sure hope it is not the case since I am looking too for one of those cards for NET on the go.
            I am using one in a home PC and it works just fine. Not sure how well it would work in a car but I'm sure that's just because of the limited range of the internal antenna. If you have a card with an external connector then there should be no problem at all.
            Rick S.
              Good to know, I'll call Verizon tomorrow for details, also Sprint has it, but I think Verizon has better coverage.
                thank you everyone! :-) my gf will definitely be happy that she doesn't have to pay for DSL or dial up now. heh.
                here is the card on verizon wireless:
                http://www.verizonwireless.com/b2c/s...edPhoneId=1517
                and from the manufacturer:
                http://www.audiovox.com/webapp/wcs/s...2526&langId=-1
                I am definitely sticking with a 32 bit one. i don't need the headaches of a 16 bit card.
                the verizon card *does* have a little jack where an antenna could connect. I was able to find that you can hook an external antenna into the card, and boost its signal 1-2 bars:
                http://www.yourwirelesssource.com/Ph...VERIZON+PC5220
                  almost the same hunt
                  I too am looking to know if such a device exists, however, I dont have the ability to use a PCI slot, does a usb/firewire to cardbus/32 exist. Essentially, Im looking for a dongle that connects to a pci port, and provides a cardbus/32 port for placing a pcmcia GPRS card into...
