Compact IR Reciever
  • Compact IR Reciever
    Hi, I just found this product, I don't know if it has been listed here before but i like it over the IRMAN becasue of its compact size.
    http://myweb.tiscali.co.uk/dusan/ir_receiver_01.htm
    They have a USB and Serial Version. it costs about 35 dollars shipped to the US.
    It is compatable with Girder.
    I will be ordering one.
    thats very cool, I like the idea of USB
    That looks exactly like the one I use in my car except I built mine, works perfectly with girder.
    I was lucky enough to find the IR receiver in a directv unit I had.
    肚子笑痛了
    S60 Install
      If i had time i would build one too. Thanks for posting the scematics.
      I can't wait to be able to control my system with my remote
      I got this super slim one off ebay a while back
      http://www.mp3car.com/vbulletin/show...6&postcount=18
        The guy's got auctions on eBay going for 4.99 + 2.90 S/H to US (British Pounds). In American $ this equals...$14.76 out the door. Not sure how important the USB version is to you.
          dude i made 2 the other day for a total of $20 bucks. so 10 bucks each.. and i got it just as small... i used lan cable small piece of pcb and the components.. it works great. and the best part is for 18 bucks more you can get a usb to serial adapter. GL DON'T BE LAZY!!
          Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
          Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
          S2000 Carputer
            yeah i'm pretty much doing the same exact thing, except now i'm looking for a steering wheel remote so I dont have a remote rolling around the car.
            肚子笑痛了
            S60 Install
              So with may calculation ($31.82 shipped) I will pay for the USB version and and have someone else make it for me for about the same price ($28 from your posted cost). Thats not Lazy, thats smart.
              So how much is your time worth? Obviosly less than mine
                I should have a review sample coming from www.IR2PC.com this week. Check out my web site for more info (www.hnetinc.com)
                  I built this one too. You can get all the parts at radio shack for under $10. It's easily assembled in less than 1 hour.
                  2004 4runner
                    That one looks good too.
                      I built 2 of those base on the schema above cost about 15 or less for 2. All parts order from digikey at the same time I order parts for the Sproggy.
                      You can have all the supporting parts (resistor, cap, regulator, diodes all in the Serial D9 housing and extended the IR sensor with 3 wires to wherever you want.
                      Y2K Accord Dell GX150
                      EmoRebellion is a SCAMMER
                        yeah well im just using the serial version bro... but do whatever you feel is best
                        S2000 Carputer
                          nOObie chiming in! I understand the receiver part, but what remote do you use? I have 4 old Directv boxes sitting around with remotes. Do I make the circuit and load Girder and use the DTV remotes?
                            Where one gets a housing that is big enough for every thing, I looked all over, then again, I tend to miss things.
                              @kingtut: It should fit in just about any housing as long as you use the 78L05 and not the 7805.
                              @Dudes99: It should work with most remotes you have lying around. Some work on slightly different carrier frequencies than what the IR reciever uses but mine worked with every remote I had lying around.
                              2004 4runner
