5" DVD DIN adapter for In-Dash Mounting
  • 5" DVD DIN adapter for In-Dash Mounting
    Hi... I am finalizing my Carputer and I would like to install the DVD driver (a standard 5" DVD reader) in the Dash hole reserved for the Car Radio. Anyone knows if is available on the market a DIN adapter for it ?
    Thanks!
    PS I use a IDE/USB adapter to connect it
    It's a Jeep thing...you wouldn't understand !--------------------------------------------
    I am looking for the same thing without buying that one that is made for the car. I just want an enclosure or flush mount for it.
    '05 350Z Roadster
    http://www.gregburch.com/
      Well, from what I can see, you can either
      1. use a Travla C134 case (wasteful, and only supports slimline drives)
      2. for a case out on the intarweb
      3. construct something yourself
      Best of luck!
        Not sure I follow? That is a regular mini-itx case. I am looking for something to flush mount an external dvd player in a single din slot.
        '05 350Z Roadster
          Oh I see its a din size case. Thanks I will look into that!
          '05 350Z Roadster
