Motherboard problem...
  • Motherboard problem...
    Hi,
    I have been searching the forums for a week and reading, but I can't make up my mind on a motherboard. My goal is to simply play Mp3's, Gps, and maybe watch a DVD, but mainly the first two.
    I have a G35 and I have the stock headunit.
    I am concerned about power and price of the motherboard. Could someone make some suggestions. Is a via epia m10000 going to serve my needs better than a P3?
    At least if someone could point me in the right direction.
    I value your expertise.
    Also, I am going to run either a lilliput or xenarc touchscreen 7 inch monitor.
    thanks
      An epia will give you better power consumption and size, but may struggle with DVD playback or graphics.
      A p3 will provide all the power you need, but will be quite power hungry.
      I use a P4 mAtx board with a 2.4ghz celeron processor. Gives me both processing power and is good on wattage consumption. You can fit these boards in micro desktop cases, and I haven't found space being an issue.
        Uhm.... The P3 is easy to power compared to a P4
        TruckinMP3
        Read the FAQ!
          just what i was thinking. P4 alone uses the power or a P3 + mobo. If youjust want something small and easy go epia 1 or 1.2ghz. they have hardware dvd acceleration but they can't do the native resolution of the 7" widescreens but most people jsut run in 800x600 mode.
            also epia will cost about the same as a P3 setup but the power supply is a lot cheaper for one of those - eg m1-atx from the mp3car.com store is $75 or summit. Get s slot load DVD (laptop one) linked by firewire or USB2 and a USB or PCI soundcard (onboard is crap). Job done!
              I like my onboard sound the MB has integrated sound vid and lan.
              http://www.softwareandstuff.com/MBB10389.html
              I used a CPU and memory I had laying arround and the MB was $20.00
              So far the only items that I spent much money on are the DC to DC PS and the 14 inch LCD....Total less then $350.
              TruckinMP3
              Read the FAQ!
