What Do You Think About This Pc? Will It Work In A Car? [email protected]@k
  • What Do You Think About This Pc? Will It Work In A Car? [email protected]@k
    hi from Sergio
    i am new to this site and need some help
    can you tell me if this computer is a good one to use in my car sice so many
    are experts at this and used many different ones how about this one
    am also considering buying the units for resale so what do you think?
    ALSO WILL IT SUPPORT A 7 INCH TOOCH SCREEN VGA AND HOW GOOD IS
    THE SOUND ON THIS BOARD
    thank you
    Product Name: CAR PC USA
    CPU VIA Eden 10000MHz (BGA)
    CPU Voltage / FSB 1.05V / 133MHz
    Power Management APM 1.2
    Chipset VIA CLE266 - North bridge:VT8623* 548 PIN BGA; South bridge:VT8235
    VGA CLE266 Intergrated AGP8X, Shared System Memory 64MB Max(one channel LVDS interface)
    BIOS Whizpro BIOS* 4 Mb with etBIOS
    LAN Realtek 8139C, 10 Base-T /100 Base-TX Protocol (wake on LAN)
    Sound Realek ALC650 on board controller + AC97 Codec (Line-out, Line-in, Mic, S/PDIF out),On board Pin header Type
    Memory type 1xDDR memory module,2.5V PC133/DDR 266 (without ECC function),MAX. 1GB
    LPC I/O VT1211: COM1, COM2
    KB/Mouse Controller VT1211 Built-in
    Card-bus(PCMCIA) TI1410 PCI single chip Card-bus controller support 1 channel
    Local bus IDE VT8235 build-in, IDE1-40 pin box header(Ultra DMA 33/66/100/133), IDE2-40 pin box header
    Power Connector DC-in 19-24v /7.5A-8A ( DC TO DC Module 12V/5V/3.3v)
    USB 2.0 6 ports; 4x D-TYPE connectot and 2x pin header; transfer rate up to 480Mb/S.
    IEEE 1394 2 ports ; VIA VT6307S IEEE 1394 Firewire
    IrDA (Infrared) Included in south bridge, pin-header
    I2C Included in south bridge, pin-header
    Onboard Connector (Front-Side) DC-JACK (DC-OUT ),19V-24V
    Onboard Connector (Rear-Side) 1x RJ45; 4x USB connectors (D-type); 1x PCMCIA Connector; DC-JACK (DC-IN )
    Onboard Slot 1x PCI slot
    Docking Pin-Header 2x additional USB 2.0 ports in Pin-Header(2x5x1)
    2x 1394 ports in Pin-Header(2x5x2)
    Audio connectors in Pin-Header(Mic, Line Out,Line In)(2x4x1)
    CD Audio-in Pin header(1x4x1)
    AUX-IN Pin header (1x4x1)
    FIR Pin-Header (1x5x1)
    CPU FAN, Sys FAN (1x3x2) -- Have thermal control
    1x I2C connector in Pin-Header (1x6x1)
    1x LVDS connector (20 pin)
    1x Inverter connector
    2x Serial port Pin-Header(2x5x2)
    S/PDIF out
    2x IDE Pin-Box Header (2x20x2)
    2x IDE Power Pin-Header (1x4x2)
    PS2 K/B,Mouse Header(2x3x1)
    Pin-Header for PWR B/T,PWR LED,HDD LED (2x4x1)
    1x VGA Pin-Header (2x6x1)
    Dimension H 50mm X D 200mm X W 145mm - With aluminum Thermal-boxed solution
    looks like this is just your standard via M1000 board and a case. It's what most people here use. Just make sure you aren't overpaying for the "kit" when you can probably buy it for less somewhere else.
    EDIT: Actually this is a 10 GHz processor according to their specs. So its a damn good system. I want one for my office.
      They are using AMD's Mhz measuring system, it is actually only as powerful as a pentium 133 mmx with the overdrive processor to 200Mhz. You'd be better off with a 1000 monkey's at typewriters, but reproducing hamlet may not be one of your goals
      steve
      steven n
      95 Saturn SC1
      Alpine 9831 + Blaupunkt SR04
      Stereo Integrity 327 Comps + MTX 4244
      Resonant Engineering XXX 18 D2 + Elemental Designs Nine.1 + 7.5ft^3 tuned to ~29Hz
      Carputer Progress: Rethinking, box has consumed my trunk
