Carputer "skipping"
  • Carputer "skipping"
    i finished my install and now i notice that when playing music or videos the carputer will "skip" for half a second then resume.
    I have a M10000, 512 DDR, 80 Gig HD
    anyone else experience this problem and is there a fix?
    how often does this happen?
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
      mine does that occasionally.. more often than not, i think it is when it is cold and just starting up.. mine sounds like a cd skipping, even though it is playing right off the hard drive. it only happens a few times though.
      Craig
        happens randomly. the screen also freezes for a split sec. it does it regardless of if the system was on for a while or just started. very random. i haven't noticed this when doing anything else besides viewing music videos or playing mp3s.
          Mine does it ALL the time... especially when I have a visual on the screen. The M10k just doesn't have enough CPU IMO.
            i know that others are running M10k with no problems. but i agree that it happens more often with visuals on screen
              Is this on video/music you play on a CD/DVD drive?
              If yes, is the drive connected to a USB to IDE converter?
              If yes, then probably the limitation of the converter that makes it skips.
              EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
                mine only does it very rarely and mostly when it is cold.. i am using a MII10000, an Opus 150w, and an PCI Audigy 2ZS.
                Craig
                  Do you have a WiFi adapter installed?
                    USB GPS units can cause this problem - making playback jerky and can upset sound as well when GPS tracking is switched on.
                    Might be worth checking,
                    Cheers,
                    Andy
                      yea, i think ill try unhooking the GPS reciever.
                      This problem occurs with the music and music videos playing off my hard drive.
                        What software are you using for this?
                        Debt as of 1/1/05: $34,354.48
                        Debt as of July 4, 2007: $0.00 explanation
                        I'M DEBT FREE!!
                        I'm now a reasonably successful gunblogger.
                          im using frodoplayer.
                          it does this also when playing media in windows media player.
                            ok, so after searching a few times i think i found the problem. others found that it was the PCI wireless card.
                            time to pull it out and see if it was the problem.
                            thanks for your help people.
