New XMD1000 Not Working!
  • New XMD1000 Not Working!
    Allright, I just got my new XMD1000, I turned off the pc, pluged up the Direct Link Cable to the XMD, Pluged up the power Supply, and turned on my pc. Went straight to MMC and it told me that there is "No Supported Radio Hardware Found"
    Same error the last one told me. I did the XM Debug program and tons of sends but no recieves. Someone Please Help me soon! I need to call up XM really soon to tell them they owe me 2 months of service for the time it hasn't worked.
    -Josh
    1997 Mitsubishi Eclipse GSX
    My URL: https://www.facebook.com/jagray85
    XBOX: DarkerStars
    try my new program and see if it works
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
      what program? Frodoplayer or a debug program?
      -Josh
      XBOX: DarkerStars
        http://www.mp3car.com/vbulletin/showthread.php?t=40900
          Software wont work. I dont know why I didnt' tell you. The debug program started and sent tons of codes but didn't get any recieves from the XMD.
          Something else has to be wrong with my pc or something.
          -Josh
          XBOX: DarkerStars
            You set the ports right ?
            [H]4 Life
            I'm a lesbian too.
            I am for hire!
              Allright...I downloaded the XMDebug program onto my dads pc...activated his com port, and I put a jumper on both my cables...both worked...so I hooked up the XMD1000 to it...and IT WORKED!!!!
              but what sucks about this...is that now I know something is wrong with my pc.
              -Josh
              XBOX: DarkerStars
                Allright, I got it working on my pc...but on my dads pc all the channels poped up on the debug program...only channels 1 and 247 load on my computer on both the debug program and mmc.
                -Josh
                XBOX: DarkerStars
                  give it time, just means it needs to remember it's activated, checking it with the frodo xm application are you getting any signal?
                  肚子笑痛了
                  S60 Install
                    Frodo's program isn't working at all. MMC it says the signal is Excelent. eXeM says it is getting Excelent for the signal.
                    -Josh
                    XBOX: DarkerStars
                      did you edit the ini for frodo's program to reflect your comm port? and did you have XM send a refresh to your unit?
                      肚子笑痛了
                      S60 Install
                        Ok, I told XM to activate my unit today...and nothing happend for 40 minutes...so I opened eXeM and some of the channels opened up....but for some reason on eXeM, I can't hear anything.
                        So I go back to MMC, and some of the channels load, and then stop, and I can only play channel 001. But it shuts off after a minute or so..whats goin on? It hasn't been 2 hours yet...should I just leave mmc running? I got all the channels to pop up on the XMConfig program.
                        Everytime I reopen mmc or eXeM, a different ammount of channels load. So sometimes it could end at 40, sometimes it could end at 247, or sometimes it will end at 20. its all various. and I can't listen to the other channels. Only 001. Should I refresh?
                        -Josh
                        XBOX: DarkerStars
                          Ok...I just loaded eXeM and instantly selected a diff channel...and for some reason my line in keeps muting. But I got that channel playing....but I can't change the channel.
                          HAHA, while typing this message, the music stoped playing.
                          -Josh
                          XBOX: DarkerStars
                            Ok, now my computer doesn't see my XMD...WTF is going on?
                            It was working somewhat....but I started hearing these sounds like the unit was turning off.....and then I tried opening it up in MMC and it told me no radio hardware found. So I ran the debug program and it doesn't get any recieve signals. only send.
                            -Josh
                            XBOX: DarkerStars
                              Allright, I have the XMD on my dads pc...and eXeM doesn't work right....but I ran the frodo xmdebug program on that pc...and found out you can listen to music that way....its working.....All channels poped up, I'm changing channels, listning to music...so Whats wrong with the software?
                              -Josh
                              XBOX: DarkerStars
