EPIA Composite out problems
  • EPIA Composite out problems
    Hello,
    I am running an EPIA M10000 in a car and trying to use the composite/s-video output together with the VGA output (for TV screens in the back).
    When I run the VGA just by its self (800x600), it works great, and there are no problems at all. However, if I enable the "TV" check box in the display settings, the composite line gets video, but the VGA gets major vertical overscan.
    It's hard to explain so I drew a quick crappy pic.
    The screen is a Xenarc BTW.
    So does anyone know what could be the problem? It seems like it is something that has to do with the graphics drivers. I am using the latest S3 drivers off the manufact site.
    At least you get a picture...I don't.
    Renault Megane...the OEM look
      Overscan is pretty common. Don't know how the EPIA does it but on most video cards the overscan can be controlled from within the video card drivers.
      Rick S.
      XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
        Yeah, the funny thing is... I can control and FIX the overscan on the composite output, but I CAN NOT fix the overscan on VGA (which is what the actual problem is)
        Anyone else got any ideas?
          hmm thats wierd i have VGA and composite onscreen yet I havent touched the TV option in the display settings.
          CarPC Status:
          GPS: 99%
          Hardware: 99%
          Software: 92%
          Case Install: 99.9%
          Dash Install: 100%
          Car Install: 72%
            Do both outputs show overscan or just the VGA? Maybe your refresh rate is being changed when you enable the composite out?
            Rick S.
