Anyone using Timetrax + Sirius solution
  • Anyone using Timetrax + Sirius solution
    Anyone using the Timetrax Sirius solution? I'm on to something here and need to get some info.
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
    I'm pretty sure it's not available yet. The site let's you pre-order.. says they will be in stock "soon".
      /smacks forehead/
      I guess I should learn to read.
        If you are familiar with the XM interface for the XM Direct, it is probably the exact same software front end - I have it, and I love it.. Very easy to use, and it does everything you've heard it does.. The SIRI version uses a Kenwood KTC-SR903 Sirius hideaway tuner, which normally attaches to a Kenwood head unit. Looking at the picture, there is a "To Controller" port, which is the same DIN-8 connection that the XM Direct uses. Assuming this is a regular RS232 serial connection like the XM Direct, all they have to do is change the XM adapter pin configuration to match it.
        Save XMLM! Sign the Petition: http://www.petitiononline.com/liqmetal/
          Timetrax front end
