Need Help with Idea!!
  • Need Help with Idea!!
    If I took my modded xbox and connected the video(yellow) to the a LCD screen and took the sound( red & white) to an eq would that work would I be able to get good sound out of my amplifiers to my speakers and sub? I really need to find this out because I was planning on installing a carputer but I dont have all the cash right now already have an lcd and the eq. Thanks in advance.
    Um the Auxiallry voltage coming from the xbox is around 1 (or even less, 800mV or something) which is far less than head units output (2.5 to 5V generally). The EQ may help because you can increase the signal, but i am unsure if it will increase it enough. With a too small signal, you have to crank the gain and it will probably sound ****.
    You can look into linedrivers...i think theyre expensive. I also use a modded xbox, but i bought a new head unit specfically for the aux in feature so that it could all be controlled nicely (albeit expensively)
    Hope that helps
    Progress 50%
    Next Step: Making Enclosure, Hard Wiring PSU
    Thinkpad 1Ghz P3
    256MB RAM
    Lilliput Motorised
    80GB 3.5"
