mounting casing in trunk
  • mounting casing in trunk
    What is the best way to mount a Morex 2677 case to a trunk ceiling in the car? What does CD shuttles use?
    CD changer brackets and a screws or straps. you can easily make somethign out of strips of metal.
      Velcro
        Originally posted by wi77iam
        Velcro
        Velcro works wonders
          Does velcro actually keep the case secure to the trunk. How velcro do you guys actually use? A few strips or do you cover the whole bottom?
          Installed
          Asus A7N8X-VM - AMD Mobile Athlon 2400
          512 Ram - 60GB HD - Opus 150w
          Lilliput 7" - Rikaline 6010
          [00000000000001100010-] 98% Completed
          Check Out My Install!!!
            I just used a few strips. I went to the hardware store and picked up a pack of industrial strength velcro and just used the side that sticks to the carpet. It's really stuck down there...
              Originally posted by naquada
              trunk ceiling
              Velcro will support this? Wow. I'd say even bungees would provide too much slack. May want to try metal straps or rope.
              http://www.jeepmp3.com/
              CarPC Stolen. Starting over.
              Ne1 recognize the avatar?
                I can see velcro supporting it if it's using gravity to help it, but in this guys case.....gravity will be working against him.....
                Jan Bennett
                  Wow, show you how careless I am at reading. I read mounting case in trunk and automatically thought to the floor.
                  Installed
                    lol - it happens!
                    Jan Bennett
                      I mounted my 2699R case vertically to a board in the trunk using two strips of industrial strength velcro. I have to use a crowbar to pry it off when I need to do maintenance on the case. Once the case started bending before the velcro would let loose. That stuff is amazing.
                        Yea they make some friggin' strong velcro now adays. You gotta find the stuff that looks like hard plastic. It's really strong.
                        Dak TruckPuter:
                        Mac: - Researching and Awaiting Funds
                        Changed to planning for a Mac Mini Trukputer...w3rd.
                          Grimey... you mean the stuff that is hard plastic on both sides? I forget what its called now :-\
