Anyone use this USB hub? Question on "non-powered"
  • Anyone use this USB hub? Question on "non-powered"
    I am tring to find the perfect hubs for my setup and in my search I found this: http://www.newegg.com/app/viewProduc...factory=BROWSE
    Has anyone used it, or one like it? The part that is throwing me is the "non - powered" part. If you look at the pics it has what appears to be an additional USB/power cable.. looks like you have the option of useing one of the USB ports to provide extra power, or you could something else into the end that plugs into the hub, but i am not sure what..
    I found the spec sheet on the manufactures website and it says that the 7 ports all provide 500 milliamp. How is this possible if it is only powered by 2 usb that would be only 1 amp. right?
    link to manufactures page
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
    ha, thats the same hub i got, havent installed it yet...and havent tested it. About the not powered part....it has the connector, just doenst come with the power adapter. thats really all i can say.
    PC Components:
    My work log
      does the usb power cord go into the 2v power inlet?
      My Install
      Software:
      CFiG v1
      CarShell
      StopWatch
        That's not a 2v inlet that's a 5v at 2amps inlet.
        '99 Accord LX
        Pics of CarPC Setup
          your right, sorry brain was thinking one thing fingers typed another
          is there a way to get 2A from a USB connection? I thought the max was 500 milliamp...
          My Install
          Software:
          CFiG v1
          CarShell
          StopWatch
            Yeah, that makes sense. If the max amperage per port is 500milliamps then multiply that times the 4 ports and you get 2 amps. I don't think all devices use the full 500milliamps though.
            '99 Accord LX
            Pics of CarPC Setup
              but its a 7 port hub
              My Install
              Software:
              CFiG v1
              CarShell
              StopWatch
                Oh, hehe, didn't notice the 3 on the back. Ummmm, I guess you can't run full load on every single port then *shrugs* I don't think that many devices do anyway.
                '99 Accord LX
                Pics of CarPC Setup
                  This port is perfect for what I am looking for having the 7 ports, and the way they are configured. by having the ones in the back and front I can mold it in the dash and have installed components plug into the back where they are out of sight and have the front ports availible in the cablin of the car.
                  It will be pretty loaded up, touchscreen, obdII, mic, wireless g, bluetooth, possibly a keyoard and/or mouse at times. I dont mind running 5v up to it, as I planned on doing this for my slim slot dvd.
                  @peoples what is the other side of the hub end of the usb power cord for? Is there a optional plugin cord?
                  My Install
                  Software:
                  CFiG v1
                  CarShell
                  StopWatch
                    You could buy a right barrell connector from Radioshack and solder on the 5 volt and ground wires from the PSU pretty easily. Then you wouldn't have to worry about it losing power under a load running on only the USB bus power.
                    '99 Accord LX
                    Pics of CarPC Setup
                      that seems like a good idea to me, thanks for all the help!
                      My Install
                      Software:
                      CFiG v1
                      CarShell
                      StopWatch
                        my bad, my hub is the 4 port version of that
                        PC Components:
                        My work log
