Look what I scored
  • Look what I scored
    A friend of mine just gave me this Dell Latitude C600 (company was going to throw it away). It was missing memory and CD player. So I took the memory out of two older laptops (one works and the other is broke). I picked up a CD player and C-Dock II Docking Station for $45.
    The laptop
    Notice the Wake/Event Resume and the Wake on LAN options in the BIOS
    The docking station
    The left side of the docking station
    the right side of the docking station
    The back of the docking station
    hey i got the same one for free too. dupont was so nice
    Falcon cr53 w/ via epia m10000. Nokia 3650 blutooth phone.
    Better than winamp. Click here for qcd player.
      Yeah you can't beat free
      dupont
        damn, that docking station is huge!
        beer replenishment fund
        mp3car live search
          What is up with the hump on the back of the docking station?!?
            hah hah, yeah it is bigger than I thought it would be but that's because you can add a CD player and two PCI slots.
            Not sure if I am going to keep it or exchange it for a regular docking station.
              Well, at any rate, you can't beat the price!
                One thing to warn you about.....
                MY company has used those for a while and recently switched to newer dells and hp's. We had some problems with those laptops. Both the 600's and the 610's have the same issue.
                There is a problem that may pop up with the touchpad. The mouse may start to drift around the screen. If this does happen. Turn it off in the bios and only use an external. If you are already using an external then just turn it off in the bios.
                The docks can also go bad. It can wear the pins on the back of the laptop.
                Another Novice?
                Progress so far <-------*-> 88%
                Kenwood MPV5025 with Aux
                Via MII10000
                512MB Ram
                LG Slim DVD\CDRW
                Xenarc 700TS
                M1ATX
                Pharos GPS
                SYBA USB2.0 4-port Hub
                Bufalo 54Mbs Wirelessb/g PCMCIA card
                  I've got a D600 (Pentium M) with the same problem. This appears to be common with many Dell laptops.
                  2004 4runner
                    Also be aware that it has WOL (Wake on Lan) which won't turn the PC on by shorting some pins from the network cable cause it's not Wake on Link it needs a network packet to be sent through to the laptop to start up and you would need a pocketpc or something to send this packet.
                    You do have the modem to wake the PC up which is good you can build a little circuit that rings on the modem to wake it up
                    CarPC Status:
                    GPS: 99%
                    Hardware: 99%
                    Software: 92%
                    Case Install: 99.9%
                    Dash Install: 100%
                    Car Install: 72%
                      Toshibas also have the wandering touchpad/pointing stick thing.
                      The C series Dells are pretty good systems (much better than the CPt's before them), but they sure seem to run hot in the dock.
                      JW
                      Powered By Sarcasm
                      Ranger: Just bought all my replacement goodies
                      Expy: Kenwood KDC-X579 from the Ranger; unknown speakers/amp & 10" Earthquake sub, that all came with the truck
                        Heckle0:
                        Thanks for the warnings. I don't plan on using the touchpad and hopefully I wont have to detach the laptop from the docking station to much.
                        NiN^_^NiN:
                        I am still trying to figure out how I am going to use WOR. Been doing some reading on the fourm and most of what I found is above my head.
                        JW:
                        "run hot in the dock" I will be sure to watch out for that, can have my car catch fire.
                          LOL, I have 2 of the exact same one.
                          2011 Nissan Frontier SL
                          AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
                          OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
                            The problem isn't THAT common though, we are also migrating to the C series but i guess we have over 30 D600's in the company still and none of them have had this problem nor any issues with the Dockingstations... not saying that it isn't so or that it doesn't happen, just saying that it maybe isn't common enough to worry about, specially when it's free
                            And you got tv (s-video) out so you can add more screens to the system, even dual screen with a movie on one screen and navigation on the other (shaky function though, but possible)
                            Are there any backsides to converting laptops to carputers vs building itx based ones?
                              I had a docking station just like that too. The big hump is space to add 2 pci cards, at least in the one I have.
                              -Drew Taylor
                              2000 Grand Am GT PC
