I cant get my computer to boot my CF Card
  • I cant get my computer to boot my CF Card
    I have a 16mb compact flash card connected to my computer via a CF-IDE adapter and it installed as the primary master drive. My computers bios picks this drive up as being a regular 16mb hard drive. However, it cannot boot at all. The computer reads this drive then freezes.
    This disk is:
    -16 mb
    -formatted in fat12
    -had its mbr modified by bootprep.exe (which is supposted to make cf cards bootable)
    -has a primary active patition
    -has all dos boot files copied to it from a windows 98 boot disk
    -i also uses sys.com to make this cf drive bootable/
    -in fdisk, the drive shows up but in Partition Magic it doesnt
    -Under computer managment/disk management in windows xp, i cannot mark
    the disks partition as active. (its greyed out)
    I really dont know what else to try, please help if you can!!
    Current Progress:
    [▓▓▓▓▓▓▓---]80%
    Final Assembly
    Ramline P3 PC
    10.4 inch Touchscreen
    Windows XP Embedded
    Road Runner
    http://www.projektnepa.com
    Electrical Engineer / Mobile DJ
    You don't need to use bootprep to boot win98. It's looking for NTLDR right now. Do you get a invalid system disk error?
    Try to get a regular MBR back on that CF card.
      ok, what is ntldr? what does it do?
      sorry, this is all kinda new to me....
      i dont get any error messages at all, the computer just freezes after the POST. There is a second or two of hard drive activity, but then it stops and the computer becomes unresponsive.
      Current Progress:
      [▓▓▓▓▓▓▓---]80%
      Final Assembly
      Ramline P3 PC
      Windows XP Embedded
      Road Runner
        you only need to run bootprep if you are booting XP from a FAT formatted CF card. What exactly are you planning to run on a 16MB CF card? You should head over to the OS optimization forum for more info.
        EWF, HORM, MinLogon on XP.
        Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
        Win Embedded Std 2011 RC
        OCZ Vertex Turbo 30GB SSD
        Lilliput 629 Transflective, WRX Screen Mount
        BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
        VoomPC 2
          Thanks, ill check out that forum....if the 16mb card would boot into dos, then id know what to do then i would invest some money into a 256mb card for windows xpe.
          Current Progress:
          [▓▓▓▓▓▓▓---]80%
          Final Assembly
          Ramline P3 PC
          Windows XP Embedded
          Road Runner
            ok just wanted to follow up, my motherboard would not boot to CF cards if they were in the secondary IDE controller, its gotta be in the primary position. and i did get it to work and bought a 512 mb card, if anyone cares :-P....
            thanks for your help...
            Current Progress:
            [▓▓▓▓▓▓▓---]80%
            Final Assembly
            Ramline P3 PC
            Windows XP Embedded
            Road Runner
