controlling the fans?
  • controlling the fans?
    i want to controll the 2nd fan on my mobo.. its a via v10000..
    is there any pograms that will monitor the speed and vary it depnding ont he temp??
    i found one program called Speedfan thats ment to do something like this but i couldnt get it to do what i wanted..
    thanks mick
    View My Blog
    Click for 2GB FREE on-line storage!
    Speedfan is what you are looking for.
      and this will work with the via board?
      all the speeds and heat and voltages numbers show up..
      i just gotta play with it some more i think..
      do u know if u can auto vary the fan speed with the temp in the program??
      View My Blog
        I'm trying to find out which mini-ITX boards work with Speedfan. None are listed on their site and I've read elsewhere that the Via boards don't measure fan speeds, therefore you can't control fan speeds using Speedfan. Is this right? and does anyone know of a mini-ITX board that allows you to control fan speeds with Speedfan?
        I'm still not sure whether Speedfan only works with 4-wire fans, or whether it can control fan speeds simply by altering the voltage through the +VE and -VE withouth the fourth PWM wire...
