Check My Electrical Config Please!
  • Check My Electrical Config Please!
    here's a rough sketch of what i'm doing tommorrow...
    i need help with proper length and gauge of the ground wires on the diagrams (big red question marks)
    how does it look?
    the device 1-3 is an inverter/dssc/relay setup - will get into that in another post...
    [4Runna]
    next - wifi
    I had always been told that you want your GND wire to be the gauge, if not LOWER gauge than your POS wire. So i would go with 4 or 2 GA wire for the GND from dist blocks. and of course, the shorter the better, to lower the risk of fire.
    Cheap Laptop, great for Carputer!
      anyone anyone:
      should i just run one fused dblock to under the rear seats then send power and ground up to the amps and have one dblock ground at 1 point instead of 2?
      [4Runna]
      next - wifi
