Powered USB Hub
  • Powered USB Hub
    Has anyone managed to use a powered usb hub? I am thinking about using one that is powerd from the battery using some sort of transformer.
    The reason for this is that from what I can work out most usb devices use 5w (is this correct?) so if you have a few it can soon eat in to my 90w PSU capacity.
    I had a search but I couldnt find much about this.
    System:
    256Mb, PIII 533 on a Hyph01 PCI sized mobo (Lan/Sound/GFX)
    M1-ATX PSU
    250GB Hdd
    USB:
    Haicom GPS
    Belkin Wireless
    Case:
    Installed in an old NTL box, (best thing for it)
    Screen:
    LinITX 7"
    Yes, run the 5V from your PSU, not all your devices will use or need the 5V supply.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
      THe idea was to use a powered hub so it is not using power from the PSU
      If you see what I mean.
      System:
      M1-ATX PSU
      250GB Hdd
      USB:
      Haicom GPS
      Belkin Wireless
      Case:
      Screen:
      LinITX 7"
        Use a 5V power regulator then...
        Renault Megane...the OEM look
          kinda simple, but I just extended the power supply cord and plugged it into a powerstrip plugged into my inverter. Works for me.
          1997 VW Jetta GLX VR6
          old HP MP
          PIII 600 or so 256 MB
          7" Xenarc
          and some plywood holding it all together
          My Project
            I have realised that the draw from usb devices is actually really low so this is not a problem, see http://www.mp3car.com/vbulletin/showthread.php?t=44687
            System:
            M1-ATX PSU
            250GB Hdd
            USB:
            Haicom GPS
            Belkin Wireless
            Case:
            Screen:
            LinITX 7"
