automatic audio switch
  • automatic audio switch
    is NE1 know where to get an automatic audio switch??? or is there such thing ?? i want to use my USB FM Radio and my MP3 player to the Line-In
    Thank you kindly
    can you explain a bit better.
      If I read correctly you search one switch automatic drive with the Line In?
      Is one interesting question profit for the one that the D-Link DRU100 for instance uses and has to pilot an electric spar from car with the Line In to have a good receipt (as I have done me) however with manual switch
      Mauri
        i have 3 plugs on my computer
        1. line-out/speakers
        2. line-in/auxilary
        3. mic
        i want to find out if there's an automatic audio switch if i want to plug my FM radio and my MP3 player to line-in ?? or can i just put a splitter for the line-in ??
          i know this is a little off topic...but why dont you just use your carputer's mp3 player???? lol isnt that what its all about?
          i got dat ***** sittin on 22s! SUPERMAN EDITION!
            This one needs a 12V trigger. Here is an automatic audio sensing one with a trip sensitivity control.
            Fabricator
              EsKALad = well, my fiance has her own MP3 player and sometimes she has her own musics, that's why i'm looking for the audio switch
              Altimat = Thank you kindly, i'll check out the link you gave me
                Make one automatic switch for use with line out(speaker)and possible.
                My dubt is to use the Line IN...(is Input no Output)....for signal to use for make one "automatic switch" hardware.
                Mauri
                  If you have a carpc then more than likely it has usb ports somewhere on it. And i know they are usually not readily available. Thats why most people locate a hub somewhere that is. And i have personally never seen a mp3 player that doesnt have a usb connection on it. I would use a usb hub somewhere on or near the dash for external mp3 players and then line-in/auxillary could be used for your fm radio. And with the usb hub you have almost endless possibilities for connections. IE> digital camera/camcorder, external hard drive, thumb drive, bluetooth adapter, etc.
                    i tried using usb to play the mp3 player, it didn't work
