front panel usb ports?
  • front panel usb ports?
    does anyone know where to get these cheaper than frontx
    http://www.frontx.com/cpx101_1.html
    this is much higher than i wish to pay as i need about 8 of them
    get a hub
      I used a piece from an old mainboard.
      Now I have 2 USB2 ports in front of my housing
      Cheap (I had a few of them still laying around) and using a dremel tool its easy to fit
      My Opel Astra 1993 CarPC: http://www.djsmiley.com/projects/carpc/photos/
        no i need then with the usb a end on the to plug in to a hub
          Ever heard of a soldering iron?
          Its not that hard to hookup a regular USB connector.....
            well then please tell me where to just but the usb a ends cause i have had no luck finding them
              I bought some USB A-A cables from an overstock sale here at a local computershop, 3m A-A for about $2 / piece.
              Cutted them into 2 pieces of 1.5m each
                this one has an external USB connector on it and a seperate power connector, and you can take it apart easy for fabbing into something.
                  thanks for the info guys i guess i will set down and make them since i suppose i won't find any premade ones cheaper than frontx
                    Is $7.90 really too expensive? https://www.2checkout.com/cgi-bin/cc...=19&quantity=1
                    Spent so far: $1,755
                    Check Out My Work Log for Specs/Pics
                    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
                    Don't mess with Texas.
                    It's not nice to pick on retards!
                      to me yes it is as I actually need to order like 5 or 6 of them (using for other projects besides in car) i can actually make them for about 2.50 each if i set down and make them
                      so to me 7.90 is to much
                        Ah, forgot that you had mentioned you needed more then one. Good luck with your project.
