Dual Display Problem on M-II w/PowerDVD
  • Dual Display Problem on M-II w/PowerDVD
    On my M-II I'm using the VGA for the front dash display and also have a rear overhead connected S-Video. I'd like the two displays to just be identical. I've set it up in XP to do that and it works perfectly except when using PowerDVD. When I play a DVD, the screens look identical except that on the VGA display, the window where the video is supposed to be is just black. The S-Video is fine.
    I'd like to get the same display on both, but if I can't, I'd at least like to be able to choose front or rear. I've played with the setting in PowerDVD for Primary or Secondary but it doesn't seem to make a difference. I've tried it w/Zoom Player and it does the same thing (although in the DVD Configuration it's using PowerDVDs video stuff).
    For BIOS settings, I've got the Display set for CRT+TV and the TV Layout setting set for S-Video.
    What else needs to be done in order to be able to get the DVD video to the front VGA while keeping it in the rear S-Video or having the rear be the one with the black video window?
    LOL, this is exactly what I am trying to achieve in my setup. I dont wont them to be identical. Now if you could tell us more about your setup/hardware which VideoCard u r using, bios versions etc. we could be of more assistance....
    Time displayed in a different way!
    http://www.lares.dti.ne.jp/%7Eyugo/s.../03/index.html
    http://www.humanclock.com/
    FREE 3D Glasses: http://www.rainbowsymphony.com/freestuff.html
      Its evil copy protection.
      PowerVoice v1 | NaviVoice Source
      GammaControl v2.4
      SKINbedder v3
      1995 Lexus SC300
        Actually it sounds like you are having a problem with Direct Draw. It seems that some video card drivers don't support using Direct draw on two or more monitors at the same time. Make sure that your DirectX and Video card drivers are up to date and look for any settings in the disply properties that might indicate a way to enable using direct draw on both monitors.
        Visit my website at:
        http://www.hostilejava.com
        http://hostilejava.com/gerbil5.jpg
          It sounds to me like you are having overlay problems. I know on one of my pc's with an ATI graphics card one screen would stay black until I changed the overlay options. After that it worked like a charm!
          I'm not sure what type of overlay control you have with the onboard video, but check in the advanced display settings and see if you can change it around.
          My 1967 Mustang
          CarPC in progress
            Thanks so far to everyone who's contributed.
            SPiTFirE definitely got the switching thing right. My M-II uses the VIA/S3G CLE266 graphics "card" (I believe it's embedded on the motherboard) and my BIOS version is 98.C7.00.16 (7/25/03). There's an Overlay tab in the Advanced Properties of the screen Settings and there's a button there that says "Switch". Clicking that does shift the DVD video from front to rear. You MUST have a DVD playing or the button isn't available. That's how I missed it. Either/or problem now solved. Thanks SPiTFirE.
            Next step is to try to get it on both without using anymore hardware. HostileJava, I'm using DirectX 9.0b. Since the S3Graphics settings stuff has that "Switch" button, it's hard to imagine it's geared up to work on both at the same time. Any other place I should be looking or anything else to try? Everything else about the two screens is identical, which is how I want it, it's just the overlay that seems to be either/or.
            If anyone else has suggestions, by all means....
              Unfortionately it sounds like your videocard driver only supports the Direct Draw Video overlay on one monitor at a time. Maybe you can find a hacked version of the driver? Usually its because the card can't handle it though.
                Why dont you try another DVD player sofftware....U never know!
                  It could just be that in your screen properties you need to go to settings and then advanced, look at the displays and make sure both are selected. If only one is the video shows on one not the other. Everything shows on both displays but video then this is probly the problem.
                    I have a M10K motherboard and I have exactly the same problem with my rear RCA screen. It seems that the M Series embedded graphics/drivers can only handle the one video overlay. I don't use DVD, I play AVI, DIVX movies direct from the hard drive, but the same problem still exists.
                    A VGA splitter might work with two VGA screens, but like me you have VGA and RCA.
                    If someone has cracked this problem, let us know how.
                    Wizz
                    Car : Ford Focus Zetec S 1800cc
                    Carpc :Galaxy GT-P1000 Original 7in Tab
                    Mounted in "On Dash" Custom Install
                      Solution
                      In chatting with the folks over on the UniChrome project at sourceforge.net it appears that the chip inside the M-II can be set to produce absolutely identical output, including overlays, to the VGA and S-Video jacks. In fact, they've hacked the driver to do just that (among other things). However, their work is done to support machines running unix, so getting that to work in XP would likely be a hassle.
                      Also, in case anyone finds it helpful, here is a link to what appears to be a draft user manual for the S3 Graphics UniChrome factory drivers.
                      Finally, thanks to a very helpful post by drait, I decided to just buy my way around this problem for about $75 by using the AverMedia QuickPlay. Works great, does exactly what it says, no drivers, no hassle. Has a VGA pass-through that doesn't degrade the picture in Windows and the video out is flexible in terms of format and looks great for DVDs.
                        Thanks for your PM. Since I replied I've been checking the spec on the QuickPlay. I think it's called KeyLite in the UK.
                        It says that there is a VGA in and a number of options out including S-Video but it does not specify a VGA out.
                        I see you mention a VGA passthrough....does this mean that I can connect this to the VGA out on my M10K and still pass the VGA signal to my VGA touchscreen monitor, while outputing to my RCA remote screen.
                        If this is the case can I revert to my original "VGA only" output and still send to both screens with an identical overlay capable display signal ?
                        Please say YES This could be the answer to all my problems.
                        Wizz
                          Hmmm....what about the opposite! Does this mean that with the S3G CLE266 you can have 2 different desktops? One VGA and One RCA? Or is it just a clone of the VGA?
                            wizz, the answer is YES. The VGA pass-through just takes the VGA from the computer and, well, passes it right through. I find there's no quality degradation when in XP (DOS text may be slightly degraded...I didn't run any tests but I don't really care). In fact, my XP display is slightly better with the QuickPlay because I was using a cheap VGA extension cable before and it didn't have a great connector, whereas the QuickPlay's screw on tight and substitute for the extension. The QuickPlay gets its power (5v) from a USB port (no data, just power, so the computer doesn't "see" it), but I was out of ports so I just lopped off the USB connector and wired it straight up to the PSU.
                            MaleBuffy, you can do SAMM with the CLE266. This means that either the video out or the VGA can be your main screen and when you drag the mouse off to one edge, it appears on the other screen. So basically you have sort of a left and right desktop. You could then, for example, put a video on one monitor and a GPS on the other. The link in my last post for the draft user manual discusses this and has examples with screen prints.
                              Thanx...it works....now if I could only use the line in and turn it line out to have 2 different sounds play at the same time and direct them to two different speakers....
