epia v restart ,bluescreen when divx playing
  • epia v restart ,bluescreen when divx playing
    Hi I'm having problem with my epia v when I play some divx or dvd it automaticly restart the comp(bluescreen).To play it normaly i have to uncheck CRT in display devices and I have to do it every time i restart PLEASE HELP !!!!
    Thanx
    other then the epia what hardware are you useing ? what type os screen, video card, dvd (usb or ide)?
    is it happening as soons as you start the dvd/divx or during playback? what software are you using?
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
      I'm using winxp with the standart onboard s3 video card Vt1621 with or without dvd-rom doesen't make difference and it happens at the beginnig of the movie always. I've used diffrent kinds of software like bspplayer,media player classic or windows media.
        Without seeing the output of the bluescreen code (which would name the module that is failing along with a hex dump) I would assume from your description so far that your mpeg video codec is borked. If you could post the error on the bluescreen would help.
        __
        Amoebacowboy
        "Do Not Taunt Happy-Fun Ball"
          The codecs I think are ok because I run it on diffrent os and it happens every time The error is 0x00000007f
            The codecs are part of your operating system, not something on the media itself. That the discs work fine on another operating system only proves the point that the issue is with your OS, either a codec issue or a display driver issue. Or do you actually mean that this happens regardless of what OS you run the discs on? If that is the case you media is hosed.
            The hex error you gave isn't enough information. 0x00000007f is just a pointer to *where* in a module's code the error is happening. Prior to the hex address you would have an actual module or system file name like NTKRNL or vga.sys. That's what is needed to help point you in the right direction of fixing the problem.
            HTH
            __
            Amoebacowboy
