If im having the pc in the boot, how do i get the cables to the dvd drive in the dash
  • If im having the pc in the boot, how do i get the cables to the dvd drive in the dash
    The ide cable and molex will need to be at least 8 feet long, how is this possible?
    Or would it be better to put the pc under a chair?
    Although the cable still needs to be 4 feet long?
    HELP PLEASE
    Use a IDE -> USB converter and then run a 8 foot usb cable from the back to the drive. For the molex connector use 4 strands of 18 gauge wire to run the power to the drive.
    edit: something like this.
    http://cgi.ebay.com/ws/eBayISAPI.dll...765747245&rd=1
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
      Whats the power supply for?
        Thats if your using the drive in your house. Then you would give the power to the drive from the power supply. You really don't need it in the car unless your using an inverter then you could use the power supply instead of running the 8 feet of wire for the molex connector.
        Installed
          There's several people using lengthy IDE cables. Do a search on "IDE cables" or "IDE length" or variations. You'll find posts on running lengthy IDE cables.
          Want to:
            i also recommend getting a IDE to USB adapter. is it a slim drive? then you will need to find one for that. and then just run power from your power supply
              Make your own IDE cables...it's quite easy.
