Help With Multi-Desktops and nView
  • Help With Multi-Desktops and nView
    Does anyone know how to display two different desktops on two different monitors using nView?
    I have the EpoX EP-8RGM3I Mobo with Dual VGA outs and nView Support, i am able to put the screens on "Dual-View" and i would think that is what I'd want it to be set on, but on one screen i get the desktop, and the other just shows the wallpaper to the current desktop, but no taskbar or icons...
    Debating on installing a carpc in my Jeep.....
    You need to setup two profiles in the nView software, then assign each profile to a desktop.
    How about the Wiki?
      and then that should show each seperate desktop on a different screen?
      ok i created two profiles, but i dont know how to assign each to a different desktop, and then to a different screen
        You cannot get Windows to (natively) show two taskbars etc. Icons aren't showing because they're put on the 1st monitor To get a 2nd taskbar, take a look at UltraMon
        Unless you want to show the same thing on both, in which case you just need to enable display cloning.
        Garry
        Co-Developer of A.I.M.E.E
        www.aimee.cc
