del
  • del
    del
    Great info! I'll be posting mine in a few months.
    Installed.
    -GPSSecure- - GPS Tracking
      I have also had the M10k in my car for one year, and I can also agree, put a push button in the dash somewhere so you can reboot it! You never know when you need to reboot it after its crashed, while mucking about with dodgy software!
      I used a 80gb hard drive mounted next to the PC, mounted verticaly under the dash. No problems.
      Used a Xenarc, no problems.
      Still use a Griffin Powermate for volume control. It still rocks
      Got a DVD/CD burner combo drive. Still havnt tried burning a CD in it!
      And I can really recommend NOT using the onboard sound, use a external USB sound card, like the audigy 2nx. Ive used that, mounted in the boot next to the amp. Sound is just perfect
      Ford XR6T blueprint 4.0 L twin cam turbo.
      Xenarc 7" touchscreen M10000 Audigy 2 NX
      ITX 120W PS 80gig HD, 256MB Ram, USB wireless internet/LAN
      Griffin Powermate Panasonic DVD-CDW
      Pioneer 5x7 Four way, 2x12 pioneer subz
      600watt 6chan USA audio AMP
        What year are you on now?
        Installed.
          Very nice job. I too have a 98 Jeep ZJ. I have all the parts together for my own car computer (Nehemiah, 100 GB 2.5" Seagate, Lilliput, etc).
          I'm planning on mounting the Lilliput in the same place you have yours with one exception. I was thinking of not using the Lilliput face but building one out of wood and bondo much like on this thread:
          2001 Jeep Cherokee Lilliput
          I thought I would mount it low enough so as to put a slot-load CD/DVD drive directly above it. I was also considering mounting the Mini-ITX board behind the Lilliput. It looks like there might be enough room there. But having seen your arm rest mount, I might go there instead. Mine's just currently full of junk anyway.
          Any input or tips for the fellow 98 ZJ owner would be appreciated.
          Thanks!
            I also bought for mine a external USB digital TV card, which worked great in the house on the TV antenna...but sucked in the car! Had to give up on it.
            It was the USB DVB ter 2.0 from Vision plus.
