Which of my systems should I run this on?
  • Which of my systems should I run this on?
    Which of the following systems should I run my CarPC on? I am going to be using the 150Watt Opus. It will also power the Mp3Car motorized in dash 7" lcd screen.
    400mhz P2
    96mb ram
    8gb hdd
    DVD-ROM
    Full ATX
    550mhz K6-2
    56mb ram
    5.5gb hdd
    DVD-ROM
    Laptop
    :-D none sell em both and make up a nice system
      Well I'm running one as a linux server and the other is going into my CarPC, so which should I use for my CarPC? :P
        Yeah, I say it time for an upgrade. but if you had to choose from the two and space is not an issue, then the first one.
        Installed
        Asus A7N8X-VM - AMD Mobile Athlon 2400
        512 Ram - 60GB HD - Opus 150w
        Lilliput 7" - Rikaline 6010
        [00000000000001100010-] 98% Completed
        Check Out My Install!!!
          Well it's only gonna run Windows 98, Winamp, and GPS so it doesn't need to be very powerful. Anyone else have a suggestion of which to use?
            They're both old slow beasts, so I don't think it would matter one way or another.
            I'd bump the RAM up in whichever one you use, specifically for the GPS.
            How about the Wiki?
              I guess I'll bump the ram up in the desktop since it'd be cheaper than laptop ram.
                I just looked on the desktop and it says it on it 120V - 4A and 240V - 2A... could that be right? If so, that's 480 watts. The Opus won't power that will it?
                  Dot worry. Opus will power it just fine
                    Ya the opus will work. Definitely need more ram though. =-P
                    Carputer status: [-*---------]
                    Im thinking laptop...
                      But is that 4 Amps, and if so... that's 480watts. So how can the 150 Watt opus run that? Also... how would I hook the Indash motorized mp3car lcd up to the opus?
                        Bump.
