m1-atx help needed
  • m1-atx help needed
    I have an M1-ATX PSU.. been running like a champ ..
    HOWEVER, I was just turning the volume up on CF and it just shutoff, I figured something funnyhappened.. maybe the CPU got too hot. or something.
    so I took it out.. the machine boots with a normal PSU .. and I looked and the FB1 component seems a bit "warmed" .. the underside of the m1-atx where the FB1 component is has a nice charred section.. only across 2 of the pads (4 total)..
    I get some fan movement if I take out the fuse and pop it back in, the fans just budge a little. nothing else though..
    I haven't looked to see if it is jsut the trace that is bad or the component is bad.. I would run it by radio chack. but they are a bunch of High School cell phone weenies that barely know where the "fun" stuff in the store is!..
    the FB1 component is by the fuse, and power in.
    PLEASE HELP..
    Shawn
    Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
    you should contact the makers of the m1.
    it might be covered under the warranty.
    2001 Acura CL traded for a 2006 Subaru Legacy GT
    7" Lilliput Touchscreen
    NANO-ITX+m1-atx
    512 DDRsodimm
    60g SATA Laptop HD
    4x Apple DVDslot
    digimoto OBDii
    mS GPS
    mini BT keyboard
    relocated HU faceplate
      I know.. but if I can fix it for less than shipping..
      of course I could ask them that also..
      mini-box.com? who makes it..
      Shawn
        ask zip-lock who makes it.
        he said he had a hand in designing it.
        NANO-ITX+m1-atx
        512 DDRsodimm
        60g SATA Laptop HD
        4x Apple DVDslot
        digimoto OBDii
        mS GPS
        mini BT keyboard
          It's made by mini-box/iTuner. You can send them email and/or PM Andrewb on these forums. You should also be able to get support from whichever vendor sold it to you.
          2004 4runner
