Audigy 2 NX and subwoofer, whats the deal?
  • Audigy 2 NX and subwoofer, whats the deal?
    OK, so it seems there is a problem getting the Audigy 2 Nx working on a 4.1 style car stereo. I have read many posts and can not get the answer I am looking for. Here is what I am trying to do...
    Run 4.1 stereo audion from my Audigy 2 NX external card.
    I have a 4 channel amp for the fronts and rear
    I also have a 2 channel amp for two subs in the trunk.
    Epia M10000 board
    no stereo headunit
    I am trying to figure out why the heck I can not get the sub to take the sub frequency. It seems it is feeding the center/subwoofer channel all to the sub. I am using a stereo red/white 1/8th adapter from the audigy. I have meesed with CMSS, 5.1,6.1,7.1, LPF slider, bass management... Nothing. I think I need to go to a mono Y RCA splitter. I dont car about 5.1 nor to I want to upconvert , I do not want to loose bass to my front and rears either. Any thoughts? I thought this would be an easy step but getting frusterated not having thumps in the trunk. Any ideas? I have seen some people sucessful, can you guys help? What cable are you running on the sub line out from teh audigy? Do you have to set to 5.1 in the mixer? I dont want to loose quality from the fronts and rears if I do this.
    My BMW 2004 330i
    I think you only need to use one of the 2 rca plugs to feed the 2 channel sub amp. Not sure if thats an option on your amp, but I know my mono amp has a mono or stereo selection option. The front/sub channel from the audigy feeds out via 2 channel mini phono to 2 channels (L for sub & R for front speakers for example, not sure if L is sub or not though). Essentially sending out a mono signal to the front speakers and mono signal to the sub.
    There is also an option to output stereo sound to the 5.1 speakers in the audigy control panel somewhere (refered to as upmixing I guess?). I have read that this option resets upon restart and/or standby/hibernate. This mode should still send bass out to your front and rear speakers. It does just what a home theatre reciever would do (most retain the lower frequencies, or have an option to set speaker size).
    I do not currently own an audigy NX, but had one for a few weeks and returned it because of some issues I have read about. Not sure where I am going to go next. The problem of it not keeping the setting after shutdown/standby seems really annoying to me.
    Anyone with more experience, please correct me if I am wrong.
      I think my amp may not accept the MONO setup on two subs. I have an Infinity Beta Digital 300 (300x2 RMS). It has a switch for Stereo or Bridged. I am wondering if I need to switch teh wiring around.
      If not, any good replacements for teh Audigy 2 NX? Just need front, rear, and sub outs in stereo. I guess I should check if teh M10000 onboard does this...
      My BMW 2004 330i
        I would first try a mono rca splitter. a single rca mono cable that splits into two mono rca cables. That would convert the mono sub signal into 2 channel mono. You would need to use the cable you have now (mini 1/8" stereo phone to male rca L+R, and then a different mono rca female to dual mono rca male y-cable)
        HOWEVER, if you are not getting any sound from the subs with the current configuration, you have some setting wrong in the audigy control panel (or the incorrect cable in the first place, which doesnt seem to be the case). The sub should at least have 1 of 2 channels if you have the mini phono to rca cable plugged into the sub (using both RCAs) and should make noise at the very least.
        Also, you can always simply split up the standard 2 channel output of any regula soundcar if you HAVE to. Some 4-channel amps also have a pre-amp output that essentially sends the rca signal it is recieving straight back out to another amp. SO, you would have the 1/8" mini phono to rca cable going into your 4 channel (which should have the ability to take a 2 channel input and send it to all 4 speakers) and then another rca to rca cable to go from your 4-channel to your sub amp. Hope this makes sens.
          thanks for teh reply. I am going to try the y splitters. What I get now is in 5.1 mode....I can hear the lady say "FRONT CENTER" when I test the channels. No major bass from the sub though. I tried teh bass redirect but no go. I am going to check my cables and try the RCA thing. I will report back tomorrow afternoon.
          My BMW 2004 330i
            Bridged mode.. is MONO on your amp...
              actually it's not same thing. the output is mixed left and right channels, so you still have to disconnect the RCA for center channel.
              you have need to make sure the amp is 2Ohm stable if you wire the sub in parallel.
                Ya, the amp is actually 1000 x 1 bridged at 4 ohms. Woudl this mean 2 x 500 if I run two speakers? Amy suggestions on the wiring?
                My BMW 2004 330i
                  I have the same setup but my subs wont be in till saturday and even then my truck is getting painted so I won't have it back for a while. I hope I don't have the same difficulties. If you solve it, post the sollution so that I'll know what I need to do. Thanks.
                  2.4 celeron
                  150 watt OPUS
                  micro atx
                  xp pro
                  tv/radio tuner card
                  audigy
                  Dual monitor Radeon
                  802.11G Mimo
                  xm pcr
                  dvd
                  gps
                  8" Lilliput touch screen
                  IGuidance
                  dual optimas
                  battery isolator
                  15" screen
                  My Truck
                    Originally posted by jedi7001
                    Ya, the amp is actually 1000 x 1 bridged at 2 ohms. Woudl this mean 2 x 500 if I run two speakers?
                    one might think it would be like that but it's not. check your amp specs but it will be lower than 500w x 2 ...
                    as for wiring the answer is what has been stated to you. On 5.1 sound cards the center and sub signals are sent out the same mini jack. So you need to take the left channel from that output, and use an RCA splitter to plug it into the left and right inputs on your amp.
                    wrap some electrical tape around the right channel coming from your sound card and just let it sit there.
                    My JeepPC Install
                    "there are no stupid questions, just stupid people."
                    "it's been agreed the whole world stinks so no one's taking showers anymore"
                      P.S. when you're running an amp bridged that's how you're supposed to wire the inputs anyway (split from the same output signal). it's a bad thing to have two signal sources feeding a bridged sub. check your amp's manual, it will probably tell you the same thing
                      My JeepPC Install
                        In my home theatre setup I had trouble with my bass also. I figured out that the center and sub come out of the same jack and in my software there is actually an option to switch which side gets which signal, so instead of having to fiddle around with the wires I just checked the box. You might want to look into that, too.
                        '99 Accord LX
                        Pics of CarPC Setup
                          Maukio, what software are you talking about?
                          My BMW 2004 330i
                            The following configuration will give you bass if everything's hooked-up correctly.
                            1. 5.1 sound - (I seem to vaguely recall an issue with the LFE channel being cancelled out by the way the Audigy mixes the channels to create it in 4.1 mode. I'm not sure if this effects you, but you might as well be safe by setting it to 5.1.)
                            2. Bass redirection
                            3. CMSS
                            4. Stereo Surround
                            If you don't want your bass "redirected" (ie: you want it going to all your speakers), you can turn off bass redirection and connect the center channel to your sub. In this case you must use the crossover in your amp. But you'll at least have control over the volume of your sub in software.
                            Also: You need only to connect one of the inputs on your amp if it's bridged.
                              ok, so I need to only hook up 1 RCA to my bridged AMP correct? Its a stereo plug from my center/sub out on my audigy. I do not need to split this to teh two RCAs on my AMP? The amp manual does not tell me what to do.
                              My BMW 2004 330i
